Old 12-12-2010, 06:12 PM   #1
zoli 16ga.
Drives: 2006 yaris
yaris brake drum
I broke a rear wheel stud and need to get the rear drum off. It will not pull off. I see two threaded holes to put bolts in to push the drum off. Anybody know the thread size?
Don.
zoli 16ga. is offline   Reply With Quote
Old 12-12-2010, 07:52 PM   #2
Klink10
Klink10's Avatar
Don't quote me, but seems like the size might be 8mm x 1.25
Old 12-12-2010, 08:48 PM   #3
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Be SURE you don't have the emergency (hand) brake set and if it still is tight to remove, relase the brake adjustment to max released position. If the linig is worn, the drum might have also worn down to have a "lip" and the lining, sitting in the deper part of the "lip" will prevent your taking the drum off. I usually can remove those small drums with a good whack with a 4X4 or a small 4LB sledge in the middle, and it loosens up. That depends though, on how much corrosion you have had accumulate with the magnesium chlorate that is used to melt the snow...... Good Luck !
bobolinko is offline   Reply With Quote
Old 12-13-2010, 05:39 PM   #4
zoli 16ga.
Drives: 2006 yaris
wheel stud
Thanks guys, job done. Took about 30min. in the driveway, but it was -26 deg. C with the wind chill ; )
Bolt to remove the brake drum is a 10m/1.5, worked like a charm.
Don.
Old 12-13-2010, 08:11 PM   #5
Klink10
Klink10's Avatar
Excellent....
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 01:25 PM
Im in Yaris heaven..... (Special Edition Yaris) YAR1S Photo-Video-Media Gallery 77 06-16-2010 11:55 PM
