Cruise Control Installation Needed
Hi,
I bought the OEM cruise control and took it to a mechanic to install it. He installed it on the steering wheel and cut a whole and everything but I guess you need to run wires for it to work. He didn't know how and I don't feel comfortable doing it. If anyone has done it to their cars and are willing to do it on mine, please let me know how much you would do it for. I would really appreciate it. ![]() Thank you very much. I live in Irvine btw. |
Too bad you're on the left coast, as I have been looking for someone local that wants cruise installed on a 07 or 08. We have many separate DIYs, but I've been wanting to do a soup to nuts install to fully document the process.
I have the pins that you'll need for the install (if you are interested): http://www.yarisworld.com/forums/showthread.php?t=31763
I wish you were near me. That would have been perfect.
I don't know if I can do it otherwise I would have no problems at all buying your custom made pins. If you can show me step by step with pictures what I should do, I may try it I don't know. I am worried I will plug it in somewhere and mess up the electrical system. |
#4 | |
http://www.yarisworld.com/forums/showthread.php?t=25515
So, don't I have to remove airbags etc again to connect one part of your pins to the Cruise Control? Also, how do I run the other end of your cable to the engine bay?
#6 | |
The wire to the ECM pin can be run through the firewall in a few different places, but most people bring it through the grommet for the AC drain hose, which is about a foot below the ECM.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 10:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| Cruise Control on 2010 Canadian Manual | Kaya B. | DIY / Maintenance / Service | 25 | 10-01-2010 04:31 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
