![]() Drives: yaris 02 Join Date: Feb 2009
Indicator relay removal
Hi folks
Gotta small problem. Was struggling to remove the haz/indicator relay on a 02 1 litre yaris. Couldn't seem to pull it out so pulled a bit harder and then found out about the side tabs when the relay and plastic mounting from fuse box snapped & came out too. Went to dealer to order new relay & asked how to remove the relay & was told dealers use tool to release tabs. What does this tool look like and how do you use it becuase i can't see how you can get anything down side of relay to do it. No room at all! Thanks Ste |
Some car manufacturers include a plastic relay pulling tool along with the fuse one. The other option is a set of relay puller pliers like these:
Pocket screwdriver?
Thanks for the replys. Ive posted a picture of the relay to show the side locking tabs. These fit into fusebox so you can see the lower diameter of the relay is smaller than the top so how can you get a tool to the tabs to release them when its fits flush to fusebox. Cover is off relay to breakage.
#5 | |
This is a photo of the fusebox with the relay plug broken off with the pins visible and also a photo of the relay with broken piece. Bear in mind that there is limited room above the fuse box also.
I finally found a reference about removing this type of relay in the service manual. It says to use a small screwdriver to lift the tabs with the blade wrapped in tape (to avoid shorting contacts that are accidentally touched).
Thanks for the info mate. Much appreciated. |
Drives: Yaris TSpirit 03 Shape lift Join Date: Dec 2010
Hello guys, I'm new here :)
can some one tell me how to remove my flasher, mine is the exact same one as shown in the pictures above. There is no way that I can remove it without breaking the thing off, Help Please! there is nothing in my service manual about it! Toyota Yaris Tspirit 2003 shape lift. |
#10 | |
| Paintless Dent Removal - Dent Magician | Chupacabra | General Yaris / Vitz Discussion | 3 | 01-27-2009 11:07 PM |
| Paintless dent removal | bugnuts | Wash, Wax, Detailing, Exterior Repairs | 3 | 03-18-2007 11:57 AM |
| Sedan Headlight removal | Go4th | DIY / Maintenance / Service | 1 | 02-04-2007 06:46 PM |
| Weight Savings - Removal, Reduction, Reminder.... | TRD_Yaris | Performance Modifications | 17 | 08-12-2006 03:07 PM |
