![]() ![]() Drives: Yaris 2009 automatic Join Date: May 2009
How to prevent scratching the Yaris bottom?
Hi all,
I have a yaris 2009. Recently I found that it's easy to scratch the bottom ,esp. the snowy day. Is there any way to ease that case? Should I change a bigger size tire (so the car could be lift up?) or any other way could do that? Thanks, Ricky |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Are you on stock suspension?
Yes, larger diameter tires will lift the car. You can also raise the suspension height. If you are only having issues in the snow with it, perhaps get some larger diameter snow tires for winter. |
wait till the snow melts
33OH,
Thanks for answering. I am currently using the original 14" tire. Do I have to change the (rim) wheel if I wish to get a larger diameter snow tire? I don't see any website talk about it. Is it unsafe if I raise the suspension? |
You can put a larger diameter snow tire on easily. It goes on the existing rim. Stock tire meaning a 175/65/14, correct?
By raising the second number (sidewall height %) you can get a taller tire. A 175/70/14 or a 185/65/14 would work nice. Both raise the car by about .5". You can go more drastic if you want, but keep in mind your speedometer will be effected. Try this tire calculator out: http://www.miata.net/garage/tirecalc.html |
I see. Thank you very much. I check it out now.
The overall item you are wanting to change is the Diameter. It's safe to go +/- 3%.
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
even if you go an entire inch bigger (which isnt suggested due to rotating mass, braking forces and other factors) you'll only gain 1/2 inch clearance
if you are having snow issues that are serious enough, i'd suggest getting a beater vehicle. in particular, a jeep. they're dime a dozen and cheap....realiable, tanks, cheap parts replacement, easy to work on. any way, get a winter vehicle. |
#9 | |
Not quite a noob
The stock psrings that came with my yaris I'm sure are made for snow.. they give the thing like a REAL 4x4 stance.
I still have them if anybody wants them. They're not in the best shape (rusty) but they were snow springs, what can ya expect. Observe.. |
Approach inclined driveways, parking lots entrances, and big speed bumps at an angle. Do not approach straight on as you will drag the nose. When lowered, you have to be even more aware of rapid changes in grade.
@ Betrivent
What's your tire size? Those sidewalls look a little short to be OEM spec.
Not quite a noob
They're stock 14s.. I think they're 185/65/14
Hmmm. You definitely got some wicked ride height happening with your springs. Would be interested to see what you measure from ground to high point in wheel arches vs me with my 175/65/14s.
Not quite a noob
I take it back, it's actually 175/65/14. Checked today
![]() Drives: 09 4dr charcoal on steelies Join Date: Oct 2010
Just build an aluminum skid plate like I did lol
Only Happy When it Rains
It isn't a real big deal if you are just hitting snow,that is going to happen on almost any car. Snow isn't really going to do any damage, and it isn't going to severely scratch anything.
Although I've heard boston way is really bad today.
Colin Chapman disciple |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
