![]() ![]() Drives: 2010 3dr LB Join Date: Sep 2010
TPMS with snow tires
I searched but was unable to find the answer. Bought 4 used 195/60-15 tires and had them mounted on 4 steelies from an 08 yaris sedan (that had the original tires w/ TPMS sensors still installed). I put 2 of the snow tires on my daughter's 08 sedan and 2 on my 2010 LB and both venicles have the TPMS light on. Is there any way to reset the light? Thanks for any help. Bill C
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
There are two things you can do. You can either re-program the TPMS sensors for each car (a pain), or do a bypass switch for the winter. I run winter tires on separate steelies, and I have the switch installed. Try this:
http://www.yarisworld.com/forums/sho...ht=TPMS+switch I zip tied the switch next to the module, which is right above the glove box opening. Just remember to flip the switch back in the summer! |
Just an update, the light has gone off on my 2010 LB after aprox 250 miles. I don't know why it went off as no reprograming was done. As far as I know the light is still on in my daughter's 08 sedan. Bill C
If you park the car near the tires/wheels that you removed, the TPMS system will actually read the sensors and clear the light. If you then drive a certain distance before the system sees them again the light will come back on.
| Review: Pirelli Winter Carving Snow Tires | Lil Abner | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-07-2010 01:04 PM |
| what snow tires good for Yaris Hatchback. | opor24 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 12-28-2009 12:53 AM |
| Tall thin Snow tires for 14" rims | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 07-25-2009 08:40 AM |
