![]() Drives: toyota yaris silver 2002 1.0 Join Date: Feb 2011
dashboard led
Bought a yaris 1.0 2002 silver well smart now all of a sudden the speedo does not work all of the rest of the lights work any ideas out there sorry my first post is like this but it is a smart looking car. Was working inthe morning now not at night.
Is this with your parking/headlights on or off?
headlights on as it is night even if i turn headlights off stays the same
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Does the Tach work?
Check the 10A GAUGE fuse
Im a total newbie at this where are the fuses ive only driven old micra before this
#7 | |
This is a diagram of what you will see: Yaris 2000 Fuse Panel.jpg
thanks il have a look and see if a fuse is gone hopefully its just that strange one all the other lights on dash work like doors temp and handbrake but not the speedo just shows to tiny red lines if its not the fuse does it look like i need a replacement speedo is it easy to replace a dash is it just plug in
#9 | |
If it does turn out to be that the speedo is bad, it is not difficult to remove and swap the instrument cluster. Th only issue is that your odometer will read whatever the replacement one reads.
Another update i love the car nice smooth drive i thought by resetting the ecu would solve it but didnt i unplugged the battery left it off for a bit connected back up speedo starts showing then 2mins later starts going dimmer then goes off any ideas before i send it off to the garage.
#11 | |
That is very strange. If you don't unplug the battery, does it still come on for about 2 minutes when you start the car, or does it remain off until you once again unplug the battery? If the latter is the case, then I would suspect a failure in the drive circuitry for the VFD.
Yes it is the latter looks like its of to the dealer
| DIY LED Strip under the door panel | charleschia1986 | DIY / Maintenance / Service | 19 | 11-05-2011 08:49 PM |
| dashboard led | splify | UK | 0 | 02-07-2011 05:59 PM |
| Green LED Dome Light and Underdash LEDs Installed | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 11 | 08-20-2010 01:38 PM |
| LED Strip Lights | ecmiyake | DIY / Maintenance / Service | 0 | 07-22-2010 11:32 PM |
| Interior LED Ricey Problem | xbr3akd0wnx | Cosmetic Modifications (Exterior/Interior) | 10 | 05-06-2010 09:50 PM |
