Old 02-05-2011, 06:33 PM   #1
dlplunkett44
Drives: 07 Yaris 4-Door
HELP: changing water pump
I am in the process of changing my water pump, but I cannot get the engine mount off. I've removed all 5 of the bolts, but where it connects to the engine half of the mount, it will not come seperated. There is a bolt hole where you can screw in one of the bolts to seperate the two, but I tried that, and the threads inside of it are now gone, so I can't use that. Is there any way that I can get this water pump off without removing the engine mount? I have the water pump loose, but I cannot seem to orient it in a way to remove it. Please help, I need to finish this very soon; I need the car tomorrow morning.
dlplunkett44 is offline   Reply With Quote
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 09:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 10:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 10:32 PM
