Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
AEM FIC Tuning
anyone know what the voltage - afr table is for the stock echo/yaris o2 sensor?
also how to switch over the controller to sent out a signal or the stock computer to read so i can tune open loop? |
#2 | |
2). If you're asking how the FIC can be set up to only send signals during open loop that's easy. You would just edit the fuel map only where the car enters open loop. If you're asking how to send a signal to the ECU to switch to open loop then that is impossible. Well, not impossible but no one has figured out a way to do so. Open loop tuning... Do it Your welcome to try and solve some of the issues I mentioned though. Personally, I went with what is known to work rather than being a perfectionist. |
#3 | |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
2) Not possible with the FIC. Focus & Pimp disconected the o2 sensor to have the car always on open loop. Not sure if both, the front one or the second one. |
Awesome!
the reason im asking these questions is that im not used to tuning piggy backs, my wrx i can just hook in my laptop and open source tune my ecu, i have found no product to do it for the 1nzfe.
so now with this piggy back i get to try to tune. i have been reading the book and i see that there is an afr-voltage table. there is also something in there stating that you can install a resistor in the wiring so the fic can output the proper voltage to keep the stock ecu happy in closed loop. is that what clamping is called? when done to the o2 or maf? at what cfm does the maf hit 5 volts? is it even possible with the t14? as for open loop.... im sure its the same for all 1zfe's? when does it switch over from closed? i know wot is open... |
#5 | |
Sensor 1: 0 to 7.999V Sensor 2: 0 to 1.275V The MAF sensor normal operating voltage range is 0.4V to 2.2V (below 0.2 and above 4.9 will trigger a DTC). The three conditions that I know of that cause open loop are coolant temp below 75C, WOT, and O2 Sensor below a certain temp (I don't remember what temp off the top of my head). I have done some experimentation with forcing open loop, but have yet to find a method that doesn't eventually set a DTC. Fooling the coolant temp input seemed like it was going to work, but keeping it in that state for more than 900 seconds (15 minutes) of driving causes an "Insufficient Coolant Temperature for Closed Loop Fuel Control" to be logged.
#6 | |
#7 | |
The way I see it is you're going to get a CEL no matter what you do when attempting to force open loop. Why not just unplug the AFR sensor and take complete control? I think the only method that hasn't been thoroughly tested in forcing open loop was by decreasing the amperage that reaches the O2 heater. I remember I was reading it supposedly won't throw a code if it's above .8A, and usually it operates at a higher amperage during closed loop. However it's likely it would throw a code anyway if it didn't heat up within an certain amount of time. Toyota =/= Subaru in the slightest when it comes to aftermarket ECU tuning lol. |
Awesome!
alright, so im sure this is more difficult with an automatic. but does anyone know where closed loop ends and open loop takes over? i also think that if i take a small amount of voltage away from the 02 sensor during boost in closed loop i may be able to get low 13's out of it, (at least away from the 14-15) if there are any fic gurus please feel free to chime in.
Just so everyone is on the same page, the Echo ECU and Yaris ECU are COMPLETELY different in their logic. The Yaris is more hard core.
You could try clamping the intake air temp sensor at -40°. I don't know if it'll force closed loop but you should be able to switch it on the fly without setting a code as the ECU would simply thing the air suddenly got really cold. Have you had a look on the Scion forums yet? They might be able to shed more light on open/closed loop as they're more closely related. |
I don't know how they differ in operation, but open/closed loop should still behave the same way.
You definitely have the right idea by subtracting voltage from the O2 to change the desired AFR in closed loop. |
Awesome!
well i went out there to tune it today, just got back, i added as much as 3.1% more fuel at 6000rpm, it sits nice at 11.1 afr. i have it set to pull 3* timing.
this turbo auto is so awesome, brake stand make the rear of the car sit 2 inches lower and then the brakes can hold 5psi off the line.. Not sure where closed loop ends so i'm using 3800 rpm to introduce fuel. no bogging issues. im impressed with this little car! |
Just be careful when below 3800rpm. Partial throttle can still make boom.
Awesome!
i know that, its an auto so if you want any power out of it, the car downshifts and all goes well.
today i'm doing some data logging and going to see how much voltage i need to take away from the 02 voltage. im going to make it tickle 13-14 afr rather then the 14-15 i see. it will make fuel mileage worse but will keep everything cooler and hopefully last longer. you can only adjust at certain voltage/rpm, so this may take a while to figure out, ill probably have to adjust everwhere but idle and under 3800rpm, unless i can find out where open loop starts and i can fine tune. not sure what psia you guys are running but im only hitting 18. 18-14.7 = 3.3psi , it is showing 5 psi gauge pressure. i think i may try a good manual boost controler to up it to 20 psia 7psi at my altitude. what you guys think? |
In my opinion, there's no benefit to be had by having a 13-14 AFR out of boost. I'm constantly running 15-15.5 out of boost, sometimes even slightly leaner, and haven't had any issues.
A boost controller would be a good idea as well. However, if you're not hitting max boost then it's likely you have a boost leak somewhere. I currently have the same problem. A boost controller would be a good idea, but if you're getting manual make sure you get the ball and spring type. |
Awesome!
there is no boost leak, waste gate is set to 5psi, i'm running 5psi.
the only difference is that 5psi here at 3800ft is only 3.3psi at sea level. as for adjusting the afr's, i hit 5psi at 2500rpm in closed loop. you cannot change only for boost, only voltage at rpm. so that is the only way to change the afr's. |
#16 | |
If that weren't so, Toyota would run the motor at that AFR too, and so would everyone else.
#17 | ||
I always thought low 15 was safe because in closed loop the mixture would generally run on the leaner side of stoich, and go as lean as 15.4ish frequently. I probably should just be playing it safe rather than trying to squeeze out as much fuel economy as possible... |
#18 | |
| Aem fic | 1.5ty | Forced Induction Forum | 17 | 08-16-2015 08:22 PM |
| aem fic $280 | 1.5ty | Items for Sale by private party | 1 | 10-22-2010 12:06 PM |
| Aem fic | 1.5ty | Items for Sale by private party | 24 | 10-05-2010 04:59 PM |
| AEM FIC works in Yaris......Sort of | cdydjded | Performance Modifications | 32 | 12-06-2009 02:58 AM |
| AEM FIC works perfectly | cdydjded | Performance Modifications | 58 | 08-03-2009 07:20 AM |
