Old 01-22-2009, 05:30 PM   #1
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
First timer Spring Installation
When it comes to anything to do with cars, I am useless. Tomorrow I will attempt at installing my springs with some professional help to guide me from a friends dad. I know that there are a lot of topics on this, and a DIY...but I am pretty nervous on fucking up my car, so any pointers would help. Read that I have to cut something off before installing the springs?
ZING is offline   Reply With Quote
Old 01-22-2009, 06:23 PM   #2
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
be ready to be pissed the front is a pain in the arssss. The rear should be left for last because it only takes like 2 minutes to installl.
Bring a rag, youll be sweating tears for the front ones
Thej3sta2 is offline   Reply With Quote
Old 01-22-2009, 06:33 PM   #3
MadMax
MadMax's Avatar
Don't sweat it, I not only installed spacers on my Jeep (which required taking the springs off and re-installing them); but I also put shocks on and I did the entire job by myself with just my usual tools. You'll need spring compressors if you can get your hands on them, if not a lot of people use ratchet straps to compress the springs. But as long as you take care jacking up your car and while it is off the ground, you shouldn't have any problems. All the do is pop in and out, basically...
A lift would make this a much easier job. It sure beats using jacks and stands like I had to with my Jeep; but once you get it done you will not only be proud of yourself for having accomplished the task, you'll also know your Yaris a little better. Consider it a "bonding" experience!
Cheers! M2
Old 01-22-2009, 06:36 PM   #4
ZING
ZING's Avatar
Bring rag: check
Compressor: check
I will be using a fully operational garage, I should be fine, I hope hehe. Well it's just a remove old/put new operations, isnt it?
Old 01-22-2009, 10:24 PM   #5
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
bandaids: check?
Triple antibioptic: check?
or gloves and somewhere to scream?(that helped me)
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-22-2009, 11:16 PM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
A spring compressor isn't really needed. Once the struts are removed, the stock springs have just a little tension on them. The lowering springs will go right in without a compressor.
Old 01-26-2009, 01:55 AM   #7
MicroHB
Drives: MY HB
true!
dont sweat just make sure to take off front plastic with wipers and you will be ok just 10 min extra of work but saves some skin on your knuckles and un needed stress
MicroHB is offline   Reply With Quote
Old 01-26-2009, 06:16 AM   #8
ZING
ZING's Avatar
Originally Posted by MicroHB View Post
true!
The installation has already been completed, check first page for pics
Old 01-23-2009, 04:00 AM   #9
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
You only need spring compressor to get the old springs off for safty......I did mine a good 7 months ago with a buddy and we were done in 4 hours,most of that was talking about how good it went........and pounding a few cold ones.
I do recomend gettign an alignment after a few weeks........or you will eat the inner side of the front tires......I finally aligned mine last week and after almost 10000 miles driving my inner tire tread was gone,old tires so no biggie but car now actually feels much better to drive aligned......imagine that.
Old 01-23-2009, 05:15 AM   #10
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
The things you have to cut are the bumbstops, the yellow thingies. There was a thread here showing the bumbstops before and after they were cut. There was a huge difference, I dont remember if it was posted before the hack or not.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 01-23-2009, 07:08 AM   #11
ZING
ZING's Avatar
DONE! took 4hrs and 30min. Yeh I do need to align the wheels...should I take it to some garage for that?
Old 01-23-2009, 07:11 AM   #12
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
take it to an allignment shop for that.
nice job! the fronts suck though. haha
Old 01-23-2009, 08:41 AM   #13
ZING
ZING's Avatar
^^ Why do the fronts suck?
Old 01-23-2009, 12:29 PM   #14
MadMax
MadMax's Avatar
ZING
Post a pic or two!
Cheers! M2
Old 01-23-2009, 01:41 PM   #15
ZING
ZING's Avatar
I will once I get home. I got a before/after picture :)
Old 01-23-2009, 02:22 PM   #16
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
The front suck because the nuts on the top of the strut towers are in a tight place,and you need to use 2 tools at once to get the nut loose.
Old 01-23-2009, 04:53 PM   #17
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Thats why you have 2 hands.
Old 01-23-2009, 05:36 PM   #18
ZING
ZING's Avatar
Thought he meant suck as in my installation sucked. Got the pics, but they don't really do it justice. Picture kinda suck as well, but it will do.
Before:
After:
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 05:24 PM
H&R spring for yaris Nas155 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-23-2008 09:44 PM
glowshift gauges combo, DF tanabe spring, + leather boot for sale cdmyaris Items for Sale by private party 19 09-28-2007 04:33 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
Save up to $40 - TWM Spring Sale! TWM Performance Sponsors Classifieds Area 0 04-03-2007 04:04 PM
