Vacuum
What's your vacuum at idle? Just want to see what every one else has.
Hmmm, I'll have to check tomorrow.
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
-21 inhg on a warm day
Ptuning.com |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
+/- 15-17. You do realize only people who are boosted will have a gauge to tell you this info. Im pretty sure very few if any who are not boosted run a vacuum guage.
^ Pretty sure that's why he posted in the Forced Induction forum.
yup
Ptuning.com |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
15-17 on start-up...20-21 once its warmed up
05' Echo Hatch - Greddy Supercharger - rear disc |
Ok thanks I ordered a new boost gauge and just wanted to see what I should be expecting in vacuum. Previous gauge did not have that.
some things which can affect vac reading at idle... electrical load, afr's, and aftermarket cams. a stock, healthy motor is about -20 inhg. If you see -17 warm with ac off and proper afr... do a leakdown test.
Ptuning.com |
#11 | |
mine is about -23 inhg but still trying to figure out why my idle afr is soo lean. I am making a boost leak tester right now to see if i have a leak. And also my idle is rough bouncing all over the darn place 300-1000rpm.
strange, maybe your intake manifold has something to do with that. Last time I had vac that weak my piston ringland was cracked.
Ptuning.com |
sounds llike a flakey primary o2, or exhaust leak before it.
Ptuning.com |
need alittle help. Is there another spot i can tee into for my new BOV? I want it to have its own vacuum/boost source. I am currently running everything off the intake manifold.
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I had the same problem with the lean, bouncing idle condition. Some times it would even die out. I think the 02 sensor gets much hotter when located so close to the turbo. Also with the o2 sensor connected it will always be fighting the FIC and trying to correct. Now I only tune with the o2s dissconnected. My idle is still a little lean but much smoother and no die outs.
I put in a vacuum block, it makes it easy and very secure for multiple boost/vacuum lines.
I thought Golden Eagle made them, but I can't find it on their site. Here is one from Full-Race:
^^holy monkey balls.. didnt know they made those..
| Whistle at idle - vacuum leak, induction side | RichieRoo | General Yaris / Vitz Discussion | 17 | 12-16-2022 06:53 AM |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| How many MPB (miles per bar)? | otterhere | Fuel Economy Forum | 56 | 07-15-2009 05:55 PM |
| Where is are all the vacuum hoses sourced? | LtNoogie | Performance Modifications | 1 | 05-17-2009 05:22 PM |
| Vacuum Gauge vs. MPG | turboecho2005 | Fuel Economy Forum | 8 | 10-29-2008 10:20 AM |
