Old 03-29-2011, 03:20 AM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Question Eletrical problems?
So here's the two problems. 1. I got my car out of the shop from hittin a pole bout month ago and the airbag light comes and stays on......could it be linked? the airbags did'nt go off or anything.
My other problem is with my lock/unlock switch on the door for all doors. It's been locking but not unlocking, never acted up before
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 03-29-2011, 07:56 AM   #2
For the airbag light, check this thread for instructions on how to read the error code:
http://www.yarisworld.com/forums/sho...d=1#post557473
For the door unlock issue, you'd need a voltmeter to test at various points, starting with the connector on the bottom of the switch assembly, to see where the problem lies.
Old 03-29-2011, 01:01 PM   #3
Qmobile
Qmobile's Avatar
I'm thinkin I got a short somewhere......bc sometimes it'll act up sometimes it don't today it was workin perfect
Old 03-29-2011, 01:02 PM   #4
Qmobile
Qmobile's Avatar
also I have access to a dianostic tool could that tell me what's up with the light?
Old 03-29-2011, 01:08 PM   #5
Shorts cause fuses to blow or make fire. If it's intermittent, then it is more likely a loose connection.
Yaris problems and solution ubospawis Middle East 26 01-12-2011 03:41 AM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 11:13 AM
new user with a couple of problems grant_nelton Great Lakes 8 03-13-2009 10:18 PM
Problems? Twistoffate0817 General Yaris / Vitz Discussion 35 12-24-2008 11:53 AM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 11:50 AM
