Old 04-07-2011, 09:12 AM   #1
djgab101
djgab101's Avatar
Drives: toyota yaris
Yaris Halo Head Lights
Hey guys i brought these head lights and got them installed they look awesome but i am having trouble adjusting the head lights up and down!
does anyone know how i can move the head lights down cause my lights are too high!
djgab101 is offline   Reply With Quote
Old 04-07-2011, 06:05 PM   #2
Klumzyee
(^)-_-')
Drives: Amber Teradactyl on 20s
Send a message via AIM to Klumzyee
post a higher res picture.. of the back side
Klumzyee is offline   Reply With Quote
Old 04-07-2011, 11:07 PM   #3
boggydee
Drives: 2009 yaris 4dr hb
is that for 09 yaris? can you tell me where you got them?
boggydee is offline   Reply With Quote
Old 04-07-2011, 11:20 PM   #4
there are adjustment screws at the back of projector...you need to seat the headlights w/o screwing them in, see where the beam hits a wall (at dusk) and then pull out the headlights to adjust them and reseat them.
Old 04-09-2011, 04:34 AM   #5
djgab101
djgab101's Avatar
Thanks guys I finally got them working :)
They are for a 09 Yaris hatch I got them off eBay for 300 Aussie dollars they look great :)
Old 04-09-2011, 04:37 AM   #6
djgab101
djgab101's Avatar
Now that I have got them working I am trying to make my halo lights with the three LEDs come on when I open the car with the remote! I tried hooking up the dome light to the halo lights and the three LEDs but it won't work I need to find another way to make it work
Does anyone of a circuit board or DIY or method to get this working i am running out of ideas
Old 04-09-2011, 05:29 PM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
You need to hook up the dome light signal to a relay.. if you try tio just draw power fom the dome light it won'tbe enough I don't think. So you'd need a line from battery > relay > halos
Old 04-10-2011, 10:44 AM   #8
djgab101
djgab101's Avatar
Thanks for ur response if I got power from the dome to the relay to the haloes u reckon it would work? I am gonna have to shop around and look for a relay I am sure eBay or the shops have some
Old 04-10-2011, 01:03 PM   #9
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
love those lights..
Old 04-10-2011, 01:55 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Well it's just a hunch, because however little power LEDs draw when you're trying to light up THAT many lights from one source I don't think there's enough power. You can do a test like hooking up the LED's right to your battery and seeing if they light. And then hooking up only one set to the Dome circuit and seeing if they light.
Old 04-10-2011, 02:43 PM   #11
marcus
toyota
marcus's Avatar
itll work i have 10 hi leds tapped on my turn signal with no issues. i believe u only need 1 watt to run it.
Old 04-10-2011, 10:29 PM   #12
djgab101
djgab101's Avatar
U guys are legends I think it should work from the dome light i gonna draw power from their I am gonna have to get a relay tho to see if it would work :)
2006 Yaris Hatchback Replacing Stereo Head Unit help lauren24 In Car Entertainment + Electronics (audio / video / alarm) 11 07-02-2010 12:13 AM
Fitting Front Fog Lights OEM - Yaris 2007 3dr weller Cosmetic Modifications (Exterior/Interior) 1 12-17-2009 01:29 PM
