Old 04-16-2011, 02:26 AM   #1
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Tranny Fluid
Just curious for any of you with manual trannys, what kind of tranny fluid you are using? I'm at 90,000KM and overdue for my first transmission fluid change. Been reading that Red Line and Amsoil are both good choices if wanting to switch over to synthetic. I guess the Yaris only requires 2 Litres so it wouldn't be expensive at all.
white_rice is offline   Reply With Quote
Old 04-16-2011, 04:30 AM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I use royal purple.
Old 04-16-2011, 12:20 PM   #3
redline mt-90 in mine...
Old 04-16-2011, 12:49 PM   #4
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
Old 04-17-2011, 06:59 PM   #5
white_rice
white_rice's Avatar
Where can I purchase this locally?
Old 04-25-2011, 07:45 AM   #6
Viperoni
Drives: 2005 Toyota Echo
This, because it's GL-4 spec'd, which is what my Echo's tranny needs.
GL-5 will not be friendly to your tranny if you need GL-4, check your manual.
2006 Saturn Ion Redline
Old 04-30-2011, 02:36 PM   #7
Viperoni
I should clarify; any fluid that is both GL-4 and GL-5 compatible isn't the best choice, get something that is ONLY GL-4 compatible (if that's what the Yaris tranny needs).
The fluids that are GL-4/GL-5 compatible don't do as good a job as ones that are strictly GL-4 compatible.
Old 04-18-2011, 07:39 AM   #8
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
MT 90. I hate to say it but Canadian Tire can get it. May take a day or two.
soloecho2 is offline   Reply With Quote
Old 04-18-2011, 12:02 PM   #9
i got mine at JRP in mississauga
Old 04-18-2011, 08:25 PM   #10
johnny_vitz
Performance Improvements has it too I think
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 04-18-2011, 09:58 PM   #11
white_rice
white_rice's Avatar
Sweet.. I'll check Crappy Tire because JRP and Performance Improvements are both a good 1hr+ commute each way.
Thanks!!
Old 04-25-2011, 01:01 AM   #12
IllusionX
Drives: 07 Yaris Sedan Aero
hey, are the Royal Purple good?
i have castrol syntec in mine since 68k km. My gears has been grinding since...i'm at 103kkm
Old 04-25-2011, 12:43 PM   #13
since you should have changed it 33000km ago?
Old 04-25-2011, 01:36 AM   #14
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Redline MT-90, what a difference in made in shift quality.
UTVitz is offline   Reply With Quote
Old 04-25-2011, 09:48 PM   #15
IllusionX
uhh... shouldn't it be changed at every 65k?? I only did 35k so far...?
Hmmm.... Should i try Royal Purple or go back to OEM??
Old 04-25-2011, 10:28 PM   #16
tranny fluid change is every 60,000km, not miles...
Old 04-29-2011, 05:38 PM   #17
IllusionX
so should i even try royalpurple??
Old 04-29-2011, 09:25 PM   #18
SKurj
Drives: 09 Yaris 3dr HB, BRZ
I used Amsoil, got it at Autopro. Only changed it once at 200,000 kms was really pleased with it, made a noticeable difference. (that was in the echo)
SKurj is offline   Reply With Quote
what!!!! 4 quarts of tranny fluid? Moses DIY / Maintenance / Service 11 03-25-2010 01:25 AM
Used TOYOTA WS Automatic Tranny Fluid analysis : Hershey General Yaris / Vitz Discussion 15 03-18-2010 07:29 PM
Does Yaris and 2000 Corolla use same type of tranny fluid? Yawesh DIY / Maintenance / Service 6 06-23-2009 04:55 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
soo whos gonna change their tranny fluid twixt DIY / Maintenance / Service 0 08-04-2006 04:09 AM
