![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2008
What gauges you leave your SGII on?
I use:
UL - instant MPG LL - *FIA, air intake temp UR - AVG MPG, resets every startup LR - *FWT, water temp |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
If there develops a trend through this thread for certain information displayed, it could probably be a good starting point for the CTScott YarGauge default display mode.
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
water temp
MPG RPM MPH (Yeah I know that gives me two speedos, but I'm always already looking at the ScanGauge anyway) |
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
Right now:
Instant MPG Avg MPG Cost so far today MPH (I never got used to reading the center speedo at an angle )I will be changing Cost so far today to Engine load. I also realized that mine has XGauge so I will be looking for other useful gauges. |
I don't see how many hate the center gauges. They never bothered me, not even when the car was new! I kinda think gauges behind the steering wheel are weird lol.
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
I agree. And I bet most people have their SGII mounted on the center console. I do in my Tundra, easier to see.
![]() Drives: 07 sedan.04 2500hd,10 mazda3 Join Date: Apr 2011
#8 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
The whole "center-mounted" bit is a cost-saving measure, implemented so that no matter which side the steering wheel is on in a particular market, the instruments are equally, but not quite completely, unusable. I think I determined, at one point, that the parallax of the speedo at 70 is about 4 mph. The managers who approved that should be assigned mandatory community service time trying to bring Fukushima Daiichi under control, and given special radiation suits with all the warning indicators and gauges mounted on panels just in front of their right ears. -Steve |
I kept mine there, too, but my velcro peeled off in the summer heat. The ethernet cable in the back is wadded up and I jammed in between the glove box and steering wheel. It stays there on its own quite nicely!
#10 | |
Mine left no mess, just fell off one day. I thought about coming up with a solid mounting solution but decided against it since it stays on the column fine as it is. I've seen some creative mounting points for them though.
Does anyone have the new SG that supposedly displays power output? I have a first gen one, got it in May 2009. |
#12 | |
You can check bu entering MORE>MORE>MORE> and see if XGAUGE is a choice. Here is a link on how to set it up for horsepower: http://www.scangauge.com/support/horsepower.shtml |
Used to have mpg but as its all over the place its kinda meaningless for every day use so i replaced it with speed readout.
*FIA, air intake temp AVG MPG, resets after 10 hours of down time *FWT, water temp |
1. Speedometer (Since the Yaris' center-mounted one is worse than useless.)
2. Tachometer (I do a lot of mountain driving, using engine braking extensively. Some of the grades I encounter in Colorado are up to 19%!) 3. Avg MPG. 4. Coolant Temperature (I get very nervous depending upon idiot lights.) I'd really like to be able to include alternator voltage and GPH, too. Also horsepower, which is a custom X-gauge query I added to mine. |
| Autometer Phantom II gauges | cali yaris | Items for Sale by private party | 4 | 11-09-2009 08:45 PM |
| Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-20-2009 12:40 AM |
| My new gauges set up | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 30 | 04-19-2009 09:50 PM |
| Mechanical vs Electric Gauges? | PETERPOOP | Forced Induction Forum | 13 | 04-06-2009 02:25 AM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 03:42 PM |
