Old 03-26-2011, 08:00 PM   #1
bL@cKy@Ri$1
Drives: Yaris S Sedan
Unhappy Cannot figure out how to remove tail lights!
So I am trying to install hellastyle tail lights on my sedan and I tried and tried to remove the tail lights but I couldn't figure it out! I removed the two 10mm bolts and tried to pull em out but wouldnt happen! Is there anything I'm missing?
bL@cKy@Ri$1 is offline   Reply With Quote
Old 03-26-2011, 08:32 PM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
3 bolts. there are 2 along the outside and then 1 more more toward the center of the car. looking at my old ones now
Old 03-26-2011, 08:46 PM   #3
bL@cKy@Ri$1
Thanks let me know what you find!
Old 03-26-2011, 08:47 PM   #4
bL@cKy@Ri$1
But I think the sedan and hatch are different.
Old 03-26-2011, 11:17 PM   #5
If you look at page LI-123 of the lighting section of the service manual, for the sedan it says to remove the two nuts, pull the connector, and then slide the light assembly towards the rear to remove it. If it is hard to remove, the gasket may be sticking.
Old 03-26-2011, 11:43 PM   #6
bL@cKy@Ri$1
Thanks! I'll look through the manual tomorrow! Hopefully I get them out!
Old 03-26-2011, 11:56 PM   #7
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
if you need pics let me know it has 3 bolts and a plastic clip holding to the sides of the taillights which you have to reuse for the aftermarket ones
Originally Posted by sw07gt
Old 03-27-2011, 01:45 AM   #8
bL@cKy@Ri$1
Pics would definitely be helpful and appreciated Jumpman!
Old 03-27-2011, 03:25 PM   #9
JumpmanYaris
USAF_SrA_E-4
Pmd hit me up if u can 787 432 0065,
Old 03-27-2011, 08:16 PM   #10
JumpmanYaris
USAF_SrA_E-4
Nothing yet?
Old 05-04-2011, 04:50 PM   #11
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Well I am having the same problem. I removed the 2 nuts, disconnected the bulb, the light assembly just wont come out....were you ever able to get any pics Jumpman?
goliath1812 is offline   Reply With Quote
Old 05-04-2011, 05:05 PM   #12
Brian
Brian's Avatar
They're hard to remove for the first time. Wiggle them from side to side while pulling back on them. They will come out eventually.
Old 05-05-2011, 01:24 AM   #13
KevD
Drives: Blue 2007 3dr 5spd
I did this today on my 3dr. Probably pretty similar. Yeah, two 10mm nuts for mine. Then there's a plastic clip. I just put my hand in the access hole (from the trunk) and pushed outward on the assembly while pulling from the outside with my other hand. Eventually it loosened up and then POP! Out it came..
Be patient. You'll get it!
KevD is offline   Reply With Quote
Smoked tail lights: film, paint or replace? Herbicidal Cosmetic Modifications (Exterior/Interior) 30 10-19-2009 03:01 PM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 10:24 AM
FS: Yaris Liftback Tail Lights Stock OEM tekmoe Items for Sale by private party 5 06-16-2007 12:57 AM
aftermarket tail lights or tint? jamal1984 Cosmetic Modifications (Exterior/Interior) 17 01-31-2007 04:00 PM
