Old 04-29-2011, 12:02 AM   #1
jetaimejsc
jetaimejsc's Avatar
Drives: Yaris Hatchback
Speed needle
Ok, so I changed the speedometer color and everything went fine. I put it all back together and put the speed needle back and fixed it to 0 and when I turned the car on it went below 0. Next I tried to take the faceplate off and turn it on and change the below 0 to 0 so it stayed put. I drove a bit and after called it a day. Next morning the needle was back to below 0 so what i did was push it in harder and drove around and it would not move at all. Stuck on 0. Now I loosened it up again and again put it to 0 and later went out to check and again. Below 0. Hope I'm making sense here. Any help would be appreciated. Sorry for typos. Typing from iphone
jetaimejsc is offline   Reply With Quote
Old 04-29-2011, 12:22 AM   #2
rl67pinoy
Drives: 2007 Ghetto VITZ
U broke it. Lol
rl67pinoy is offline   Reply With Quote
Old 04-29-2011, 12:24 AM   #3
jetaimejsc
jetaimejsc's Avatar
i hope not. Right now its sitting at below 0. So it still moves when i accelerate, just about 10 miles behind
Old 04-29-2011, 12:32 AM   #4
rl67pinoy
I hope i can help but thats one of the things i dont mess wid in the car.
Good luck fixin it.
Old 04-29-2011, 10:56 AM   #5
jetaimejsc
jetaimejsc's Avatar
anyone else?
Old 04-29-2011, 11:06 AM   #6
matthewai
matthewai's Avatar
Drives: it is kinda stock
just put a [-10] behind every number
Old 04-29-2011, 11:11 AM   #7
I suggest taking the front cover off, and then adjusting it after turning on the ignition.
Old 04-29-2011, 11:29 AM   #8
jetaimejsc
jetaimejsc's Avatar
^ Thats exactly what i did. It was below 0 and i took the cover off and turned the car on, moved it to exactly 0 and drove around. Worked perfect. I put the cover back on and got in the car the next morning and it was back to below 0.
Old 04-29-2011, 11:45 AM   #9
Does it seem like the needle's tube is slipping?
Old 04-29-2011, 11:51 AM   #10
jetaimejsc
jetaimejsc's Avatar
not really. At first when i moved it, the needle felt loose, but i turned car on and it felt some resistance so i moved it to 0. now i pushed it in more and it never moved up or down, just stuck on 0. So i loosened it up some but after i drive and leave the car it just falls below 0
Old 04-29-2011, 11:57 AM   #11
When you adjust it powered-on, you have to pull the needle off and press it back in place. If you rotated it while powered-on, that explains why on the next trip it dropped back below zero. It only recalibrates itself on power-up. If you move the needle once it has already calibrated, you bypass the initial calibration.
Old 04-29-2011, 01:04 PM   #12
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
You always have excellent info...fun to read you excellent help info for this member.
annn is offline   Reply With Quote
Old 04-29-2011, 12:24 PM   #13
jetaimejsc
jetaimejsc's Avatar
Ok. I'll try that then. Thanks
Old 04-29-2011, 01:31 PM   #14
jetaimejsc
jetaimejsc's Avatar
Just got back and it worked, thanks CTScott
Old 04-30-2011, 03:21 AM   #15
GeneralDon7
Drives: Yaris Sedan
I had that same problem when I did my LED change, though mine eventually corrected itself back to 0, but now I have the issue if i accelerate too fast the needle gets stuck at 60.
GeneralDon7 is offline   Reply With Quote
Old 04-30-2011, 03:28 AM   #16
jetaimejsc
jetaimejsc's Avatar
mine was getting stuck at around 40ish, i retried what CTScott said and eventually it worked and just kept going to whatever speed i was going without getting stuck
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
!! Speedometer Needle Problem !!! Murtaza_murti Cosmetic Modifications (Exterior/Interior) 40 11-25-2014 10:48 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
Six speed Snyprwlf47 Performance Modifications 16 11-24-2008 09:04 PM
