![]() ![]() Drives: 2009 toyota yaris 1.3 sedan Join Date: Apr 2010
Amsoil manual gerabox oil issue?
anyone had an issue with amsoil mtf 75-90 fully synth. GL-4?
car doesn't feel smooth in shifting as before,, it was on mobil 1 , same specs help? |
that does not make sense. amsoil should be higher quality.
No issue with amsoil.
I used Castrol at first then quick switched to Royal Purple. Now I'm running Amsoil and it's been so much better. Sent from my SM-G930W8 using Tapatalk |
#4 | |
FWIW, I'm currently running Redline 75w90 GL-5, it shifts smooth but still grinds the odd time in reverse.
#5 | |
I did not have the correct RP oil, so things were not better than Castrol. I had the RP synchromesh gear oil, which wasn't really meant for our transmission. I used to grind 3,4 and 5th gear up shifts when reving high. As soon as I put Amsoil in, no more. Just going from 3rd to 5th but now that we talk about it, I haven't heard it grind doing it anymore. I still have some random grinding going into 1st from a rolling stop, but it's rare now. Sent from my SM-G930W8 using Tapatalk |
#6 | |
Try double clutch.
ok ,, maybe something went wrong in the oil change ? or maybe it is the flywheel dying ?
What do you mean by "it doesn't feel as smooth"? likely an issue with the fluid or amount, could be your flywheel/clutch but less likely
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Ive been running amsoil for over 100k in my trans with no issues.
Your clutch may be on its way out. Shifting tends to get notchy when its near the end of its life
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Manual Transmission...Safety Issue!!! | twocvforme | General Yaris / Vitz Discussion | 189 | 10-30-2010 11:00 PM |
| Question About Engine Oil | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 21 | 08-29-2009 03:08 AM |
| About Engine Oil Changing Manual | hans_fh | DIY / Maintenance / Service | 4 | 03-03-2007 10:20 AM |
