09-25-2023, 01:11 PM | #1 |
Drives: 2007 Yaris Join Date: Sep 2023
2007 Yaris Maintenance Question
Hey, I have a 2007 Yaris I bought new . All I have ever done is oil changes, new tires and new batteries a few times. Still has original everything including brakes. Best bargain I’ve ever had in a car.
I’m up to 130,000 miles and car still runs perfect. My question is should I bother changing any of the other fluids ?( Transmission, brake, differential , etc. ) or just leave well enough alone? |
09-26-2023, 07:09 AM | #2 |
Drives: 2007 Yaris 5-Door Join Date: Oct 2012
You should definitely look to replace the brake fluid. Unfortunately if you leave it too long it can rust the bore of the master cylinder causing leaks.
The coolant is probably also due and it wouldn't hurt to change the transmission fluid. What about spark plugs, engine air filter and cabin air filter? |
10-02-2023, 06:39 PM | #3 |
I would change all of them. Personally I have had good success with Valvoline Zerex Pink Asian coolant, Valvoline brake fluid DOT 3/4 and Valvoline Maxlife ATF. Our Yaris has lived a long life on these fluids.
On a side note....I use Valvoline Maxlife synthetic 5w30 oil as well.
If you want to enjoy your car, stay off of the internet. |
10-09-2023, 05:12 PM | #4 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
DO NOT change the trans fluid unless it smells burnt or is dark....
10-11-2023, 05:38 AM | #5 |
Changing the ATF will hurt nothing. 2 or 3 simple drain and fills can benefit the transmission. What's generally not the best idea is to flush a transmission with higher mileage.
10-11-2023, 07:09 AM | #6 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Yeah, by then it's too late.
10-11-2023, 08:09 PM | #7 |
With a flush you risk dislodging debris that could clog up the valve body. That's why drain and fills are the way to go on an older high mileage transmission
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
Getting ready to buy a 2007 Yaris hatch | Type456 | New YARIS Purchase Forum | 26 | 02-16-2014 11:48 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
