![]() Drives: 2007 Yaris Lift Back Join Date: Jun 2011
Looking at an 07' Yaris LB Any input?
We are looking at purchasing a 2007 model Yaris LB with 81K miles on it. I have a Camry now and have driven a Corolla as well and loved both. The car has a clean Carfax report and is in excellent condition....just needs a good detailing. Are there any mechanical issues that we should be aware of with this model Yaris? Any input would be greatly appreciated!
Only Happy When it Rains
Not really, no. It is a toyota. The Yaris has been rock solid stable, and no real mass problems of any type have shown up.
Colin Chapman disciple |
resident senior
Ask if the catalytic converter has been changed . There was a recall on the 07 LB .
![]() Drives: 2007 Yaris Hatchback LE Join Date: Feb 2011
I bought an 07 Yaris 5door LE in March and I have had no problems with it
If your near Fayetteville look me up glad, to talk with you about the Yaris. OR.....take a quik run this way. PM me for arrangements as we are heading to MN to pick up my Norton this weekend.
Find out if the AC evaporator has been replaced. If you do a little searching here for "stink" you will find that 06-08 Yaris can have an issue with the AC really stinking. There is a Toyota service bulletin on the issue (which you'll run into in the AC stink threads).
advocatus diaboli
460,000+ miles and counting. Keep a thousand dollars aside and you'll be able to fix(or replace) anything that *might* break. The engine in mine was swapped at 250K(reason unknown) because the repair was more than the cost of a complete replacement(low mileage wrecking yard swap).
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
CHECK water pump for leaks....
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 07:10 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 12:03 PM |
| Yaris TS 1.8L History and Specs | CASTREX | Yaris TS Talk | 52 | 10-27-2009 06:06 PM |
