![]() ![]() Drives: 2009 toyota yaris 1.3 sedan Join Date: Apr 2010
Hi guys ...
![]() I need help ![]() i'll be really grateful if someone shows me how to disassemble the door panel from the inside on a sedan ... ![]() THANX |
2007 Yaris Factory Repair Manual
I'm not sure which part of the manual it's in, but it should be in there. That repair manual gives you the low-down on how to pull apart just about everything on the Yaris!
#3 | |
but thanks anyways
![]() ![]() ![]() Drives: oliveMist Join Date: Apr 2011
thanks dude...
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
how I do it, on hb:
begin with the three grey panels, just rip them up. Remove the little clip that's in the front side of the panel (screw driver to pop it off). Remove 4 screws in the red pieces of plastic inside where the grey panels were. Rip off door panel. Before re-installing, check that all the clips you ripped off are in place in the door panel and not stuck in the door. You may need to buy replacements for broken clips (pack of 30 was like $15). |
is there anyway i can remove the part i've shown in red without removing the whole door ??
#8 | |
always toyin'
Mine is a hatchback so I'm not 100% sure, but it looks like there is just one screw that holds down that control module:
http://www.yarisworld.com/forums/showthread.php?t=17465 -toy .
- Procrastinators of the world unite! ...tomorrow. ![]() My Garage.. 'Mild' Drop & Misc..2-DIN GPS/Navi..DIY:Rear Wiper Delay..Ramps/Roll-Ups..Rain Sensing Wipers / Auto-Headlamps |
#9 | |
| DIY - How to remove or insert a pin on the ECM Connector A21 | CTScott | DIY / Maintenance / Service | 6 | 05-21-2024 01:29 PM |
| DIY : How to remove door panels | FEINT | DIY / Maintenance / Service | 13 | 11-18-2021 03:16 AM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 12:48 PM |
