Old 06-10-2011, 09:35 AM   #1
09BoostedVitz
Drives: 09 Yaris Hatchback
Why dosent my yaris chirp at least second gear
Does the engine not have enough power to chirp at least second gear. Every 5spd car that I have owned in the past was able to at least chirp second gear and sometimes thrid gear. In a way is kinda cool that it dosent but I am not used to it. Its this something that happens only to me or is someone else having the same problem?
09BoostedVitz is offline   Reply With Quote
Old 06-10-2011, 10:00 AM   #2
willygoodness
Drives: 09 yaris hb
try getting squeekier tires or go try on a concrete road or aim for the white lines haha
if u have a 1.3L u have to find the right revs to change gears to get a noise. if not.. maybe your clutch is on its way out ?? eh?
willygoodness is offline   Reply With Quote
Old 06-10-2011, 10:06 AM   #3
09BoostedVitz
I doubt that my clutch is on its way out, I just bought my 09 yaris 5spd with 7080 miles on it for $10,885. I got a hell of a deal power everything as well
Old 06-10-2011, 10:24 AM   #4
try powershifting?
Old 06-10-2011, 10:55 AM   #5
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Most of the reason is low power and high gearing, but I've always suspected there is some sort of restrictor somewhere in the clutch line or master cylinder. (I know some S2000's had this.) It makes the clutch engagement a little less harsh and makes life a little easier for the transmission. It would explain the slightly odd feel to the Yaris clutch. In any case, since I'm not trying to bang gears, spin tires, and break my transmission, it doesn't really bother me. I have other vehicles for that.
Old 06-10-2011, 01:00 PM   #6
Yaristeve
Drives: 3-door hatch
Originally Posted by TOUGEghost View Post
...but I've always suspected there is some sort of restrictor somewhere in the clutch line or master cylinder. (I know some S2000's had this.)
Ugh, I hope not. The IS300 has it so Toyota has a history of putting them in. AND IT SUCKS. Now I will have to go check...
Old 06-10-2011, 02:23 PM   #7
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Buy the cheapest chinese tires. They will have no grip in any condition.
Old 06-10-2011, 04:43 PM   #8
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
CHAMPIRO'S.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 06-10-2011, 10:57 AM   #9
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
You're lucky you could even find a manual yaris with power options. The only 5spd sedans I could find were all barebones crap. I ended up getting an auto because I wanted all the other options.
Old 06-10-2011, 11:05 AM   #10
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
power shifting is probably the only way u can.. gotta be quick though, and dont tear up your transmission. i havent had a problem chirping 2nd, but i can see how it would be difficult with this low hp egg
Old 06-10-2011, 11:23 AM   #11
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
stock 15's or the summer 18's i have no problem getting her to chirp....
Old 06-10-2011, 12:24 PM   #12
Where in NoVa are you?
Old 06-10-2011, 12:26 PM   #13
09BoostedVitz
Fairfax VA
Old 06-10-2011, 04:19 PM   #14
^ Best answer, LOL.
Old 06-13-2011, 09:34 AM   #15
mario98c
mario98c's Avatar
Yes you can... http://www.youtube.com/watch?v=lxSdW_foc50
Old 06-13-2011, 12:30 PM   #16
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i can chirp 2nd no problem
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-28-2011, 02:51 PM   #17
33OH
Drives: '08 Yaris
+1, no mods and no power shifting, I chirp second just fine.
Old 06-13-2011, 09:31 PM   #18
shinlee
shinlee's Avatar
Drives: 07 liftback
Yeah, a good power shift and I can chirp 2nd with my nitto 205/55/15's, but on stock rubber, just shifting close to red line about did it everytime
shinlee is offline   Reply With Quote
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 12:31 PM
Which Redline gear oil is the best for our Yaris? stevencyt DIY / Maintenance / Service 0 03-14-2007 12:11 AM
