Old 07-12-2011, 05:59 PM   #1
OTB
OTB's Avatar
Drives: 2zz MR-2 Spyder
Track guys-new coilover kit or sleeves on my hts?
I am currently running tokico hts (reds) and micro image springs. The setup is actually quite nice, but I'd like to go lower and a little stiffer. The car is damn tall, and I still have a lot of space in the wheel wells.
If possible, I'd like to find a budget way to sleeve the fronts and get height adjustable rears. (or at a minimum height adjustable fronts and rear springs that match the right height.) I saw that kngrsll did something like this here: http://www.yarisworld.com/forums/sho...ilover+sleeves
I like that setup, however it stinks to buy a set of coilovers to throw away the rears, then buy springs to throw away the fronts. I would end up with a really expensive setup, considering the tokico's aren't cheap to begin with. Perhaps there's a cheap sleeve out there that I can add standard eibach springs to?
Megan's coilover setup seems good due to its adjustablility and firm spring rates, however feedback on this forum makes it sound like they don't take the corrosion very well. This car will be driven on Utah streets in the winter, which is salt-sunshine-salt-sunshine....a perfect corrosion combo.
I'd appreciate your input.
OTB is offline   Reply With Quote
Tags
hts sleeves coilover
July 26th Shannonville Full Track lapping event! 9th event of Touge.ca! Touge.ca Canada 1 07-30-2009 04:23 AM
June 13th Shannonville Full Track lapping event! Touge.ca Canada 0 06-04-2009 07:48 AM
June 21st Cayuga TMP track lapping event, 2009-6th Touge.ca Touge.ca Canada 0 06-04-2009 07:47 AM
2009 Track lapping events, Touge Motorsports, www.Touge.ca. Touge.ca Canada 3 04-26-2009 05:49 AM
Making YarisWorld Proud- Yaris at Thunderhill in Nor Cal Vanderkitten Tracking, Racing, Auto-X Forum 23 10-24-2008 11:03 PM
