Old 05-18-2011, 09:43 PM   #1
08YARI
Drives: 2008 Yaris 2D HB
Arrow Passenger Power Window Failure
So one day my passenger window on my 08' yaris hatchback just stopped working. So I checked the fuses and tested the connnections. Everything has power. Sounds like the motor right. So i go buy a new motor, put it in and what do ya know... doesnt work! So, I tested my old motor and it works. I tested the connection that plugs into the motor and it has power when you flip the switch each way.
So whats going on?
Anyone experienced this?
THanks!
08YARI is offline   Reply With Quote
Old 05-19-2011, 02:41 PM   #2
Hartside
Drives: 2008 Yaris 1.3TR Hatchback
Check you haven't locked it using the button above your window switches on the driver door as it stops the passenger window working. Common issue
Hartside is offline   Reply With Quote
Old 07-15-2011, 09:04 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Old 07-14-2011, 08:30 PM   #4
whoknows89
Drives: 2009 Yaris 3 dr liftback
I am experiencing the same problem. It worked fine yesterday but it stopped working this morning. I'm going to take my car to the dealership in the morning. Hopefully they will be able to tell me whats going on.
whoknows89 is offline   Reply With Quote
Old 07-15-2011, 10:45 PM   #5
whoknows89
It turned out to be a loose wire
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 10:03 PM
Power window failure YarTrek DIY / Maintenance / Service 13 11-25-2013 01:38 AM
Yaris Luna 2004- Passenger Door electrical failure Ultor DIY / Maintenance / Service 2 08-05-2010 06:13 PM
Power Window Switches Stoln Australia 5 11-07-2008 10:02 AM
