![]() Drives: 2007 Toyota yaris sedan s Join Date: Aug 2011
Headlights
So I had a close call the other day while driving my car, I couldn't see a bog box in the road at night due to my fading headlights, so I decided to get new bulbs, the ones I got are a pure white 12v 60/55w with 5000k, and after driving around I was curious and felt the headlights, I was surprised with how hot they were. Is 5000k too hot for the headlights? I don't wanna sound dumb, I know headlights get hot, but I guess I never felt them after use, any knowledge and if the new lights won't be a problem would be awesome.
Thanks much |
Not quite a noob
Your headlights can take a surprisingly amount of heat. If it's just the face of them that's hot, it's fine. Consider that when you're driving you're actively cooling them with wind.
Yeah I figured that driving cools them, just wanted to make sure that I wasn't gonna have to spend 150$+ on new headlights, thanks
#4 | |
A 3000k bulb will run just as hot as a 5000K bulb. Al modern headlight bulbs like halogen quartz run hot and the headlight enclosures are designed to acomodate these higher temp. |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
You should've gotten the hid kits since it's so cheap nowadays ... Try to keep it around 4-6000k so u won't loose any lumen lights , and the hids usually run cooler than the regular bulb ... Just my .02 cents
Not quite a noob
^ Even so.. anything above 5000 just looks.. BLUE. Like, TOO blue.
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| Sedan HID Projector Retrofit Headlights | !yaris! | Cosmetic Modifications (Exterior/Interior) | 10 | 10-26-2017 03:31 AM |
| Yaris HB headlights | bambam28 | Cosmetic Modifications (Exterior/Interior) | 1 | 09-03-2011 09:43 AM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 07:50 PM |
| Angel Eyes headlights | Danish Yaris | Cosmetic Modifications (Exterior/Interior) | 9 | 02-13-2009 10:15 AM |
