Drives: 2008 yaris LB Join Date: Sep 2011
Battery color indicator
I have a 2008 Yaris LB. This morning I was surprised to have a dead battery. I jumped it and after work went to auto one to have it tested. They said it was charged 96% but a bad battery. I didn't buy a new one because I wanted my father to take a look at it. The battery color indicator was blue with a red center. This ment it was good. But I noticed that there was a groove to twist it out. When I did this it was clear with a red center. This ment it was needing to be replaced. But in the tunnel I pulled it from had blue liquid in there. So, which do I go by? Is it still good? I bought an at home charger, was this a waste of time and money??
Help! :*( |
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
If the battery tested bad, replace the battery. The "eye" of the battery really can not be trusted. It is reporting the condition of only one cell.
#3 | |
![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
Don't believe everything you hear. Canadian Tire tested my battery and said it was "bad" and wouldn't even hold a charge. I took it home put it back in the car, jumped it, let it run for 10 min, drove the car for 10 min and that was about 6 months ago or more. Mine died because I left the lights on. The battery testers don't always give accurate results, and the people operating them aren't always the smartest. looking at mine it's blue with a red dot in the center. |
![]() Drives: 2007 toyota yaris sports Join Date: Oct 2010
i would change the battery. you dont want to chance it going dead. i changed my battery 6 months after i took it off the lot just bc i wanted a good reliable battery.
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
That "blue with red dot" is useless. My Celica battery showed that "perfect condition" on the color, but the battery WAS shot.
| Tags |
| battery, color indicator |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 03:40 PM |
| Toyota Yaris Battery Light On - Repair | gabo | General Yaris / Vitz Discussion | 1 | 08-24-2011 08:21 AM |
| Charging voltage for stock battery | Vinceb | DIY / Maintenance / Service | 3 | 02-12-2011 01:10 AM |
| Installation of a Battery Isolator | frostbitten | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-07-2009 01:11 PM |
