![]() ![]() Drives: 2015 Yaris L Join Date: Jun 2017
Cruise control 2015
OK I am getting ready to do a cruise control install using whatever switch has the best reviews from Amazon or Rock Auto. It seems there are quite a few.
I will be using instructions outlined here... http://www.paulstravelpictures.com/2...ide/index.html But looking at the drilled hole in the access plate for the switch has my OCD kicked into high gear. Looks really sloppy. Anyone got a neater way to do this? Maybe a rubber grommet? Last edited by scylla; 08-04-2017 at 04:36 PM. |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Looks like it gives the same part number for the cruise control switch. See this thread http://www.yarisworld.com/forums/new...ote=1&p=801287 for Yaris specific info.
Once it is installed, you won't see the hole. I put some foam mesh from a computer cooling fan filter over the switch behind the cover plate to prevent dust entry. I believe the correct cover plate is available for a reasonable price from Toyota.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
Thanks for the quick answer, but the link you shared is for thread reply.
Sorry, my error. should be http://www.yarisworld.com/forums/sho...cruise+control
![]() Drives: yaris sedan 2011 Join Date: Oct 2016
Dear friends.
How to tell me the way connected from ECM to cruise control swich? .application for yaris sedan 2014.. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| Yaris 2015 Cruise Control & ASL | Gagi | Third Gen Yaris General Discussion | 27 | 10-05-2022 05:03 PM |
| Adding cruise control to 2015 model? | hayden | DIY / Maintenance / Service | 2 | 08-16-2015 07:43 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
