Corporate Slave
Drives: 2010 Yaris YX aka "Cutie" Join Date: Oct 2011
Paint Spray Accidental / Done On Purpose
Let me explain, it is not a full paint spray of color but more of a color white sprayed on my Yaris and it is all over, how could I remove it effectively and easy at least.
Si Vis Pacem Parabellum CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to. Keep your ride rockin and rollin |
Drives: yaris Join Date: Jan 2011
if it was waxed, the paint is likely on the wax only and fairly easy to take off
1) take a q-tip dipped in denatured alcohol and 2) try to rub a single paint drop off did it work ? a) if so, you will need a professional detail shop ( or tools) to take off the rest of it with power buffing agents b) if NOT, the paint is there to stay and you need a lot more work |
Corporate Slave
Did not try the alcohol yet, will do that.
tried Mothers Cleaner wax today though and the roughness and paint speckles is still there specially on the rubber parts and glass.
I need more stars
Drives: Liftback Join Date: Jun 2009
claybar will usually do the trick. Make sure to wax the area afterwards
Corporate Slave
Claybar??? ohhh I'm not too patient on this type.
Any idea on professional services how will they do it? with buffing wheels?
Definitey try the clay bar first.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Good luck. I dropped a spray can and the head broke off and sprayed the tail gate of my truck. Even though the truck was well waxed, nothing seemed to work in getting the speckles off. Had to scrape each one off with my thumbnail.
Making a decision without following it with an action is still a fantasy. |
Corporate Slave
Oh my situation is worst, it is like there was a plant painting on-going nearby and the wind blew in the speckles and it is all over, specially when you run your hand through the glass and roof it is all over.
| DIY: Painting Engine Cover | frownonfun | DIY / Maintenance / Service | 12 | 12-01-2013 12:07 AM |
| color match spray paint - experiences? | dmfang | Cosmetic Modifications (Exterior/Interior) | 2 | 07-28-2011 01:10 PM |
| spray paint removal of cars paint job | big lo | Wash, Wax, Detailing, Exterior Repairs | 15 | 06-19-2010 05:15 PM |
| Matching spray paint to Polar White | jdubau55 | Cosmetic Modifications (Exterior/Interior) | 1 | 03-13-2007 07:01 PM |
