Old 07-27-2011, 01:36 PM   #1
06yarishb
Drives: 2012 Yaris HB LE
Help with fog light installation
I follow this instruction (see attached)and after all done...fail. The fog swich ligh is on and off but seem like no power to the fog lights. Can someone help? I have exactly fog light kit like the author.
06yarishb is offline   Reply With Quote
Old 07-27-2011, 02:07 PM   #2
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
Does the foglight indicator on the Instrument Panel come on? Do you hear a click when you turn on the switch?
PROX4x4 is offline   Reply With Quote
Old 07-27-2011, 02:10 PM   #3
06yarishb
nope the fog light indicator on the instrument panel doesn't come on. No click. What am I missing? I double check all wiring many times and give up
Old 07-27-2011, 03:03 PM   #4
PROX4x4
Try connecting the Pin#2 as shown on your attachement on connector D4, if the lights come on then the problem is with the switch wiring.
Old 07-27-2011, 03:04 PM   #5
PROX4x4
Sorry, connect pin#2 (as shown on your attachment ) to the car ground.
Old 07-27-2011, 07:24 PM   #6
06yarishb
ok what exactly that do? YOu mean this?>
Old 07-28-2011, 12:26 PM   #7
PROX4x4
That pin#2 was accoding to page 6 of the file you attached here, but according to above (which is the correct numbering) ground the wire in pin#3 (second from the left, top row).
Old 07-28-2011, 01:03 PM   #8
06yarishb
what exact that does anyway? I thought that is the signal or turn on the power for the fogs...there is one ground from the switch already hook up. I will give it a shot and see how it goes.
Old 07-28-2011, 01:06 PM   #9
PROX4x4
Pin#3 is the the ground wire to the relay switch, if your lights turn on then it means you are good with the lights, lights wiring and relay.
Old 07-29-2011, 11:45 AM   #10
06yarishb
no cigar...after I ground the pin#3 the light from the fog switch is on when I turn on my headlights but when I push to turn on the fog the light on switch turn off. Also I just found out my left signals are not working...where is the fuse for that? May I blew the fuse somehow..I checked the bulbs front and back they look fine...can\t find the fuse for the signal lights. :(
Old 07-29-2011, 12:12 PM   #11
They both operate off of the 10A HAZ fuse (in the under hood fuse panel). If that fuse is blown then neither should work.
Old 07-29-2011, 12:31 PM   #12
06yarishb
damn...check that 10a haz fuse and it looks ok...only the left signal doesn't work the right side is ok. When I flick left it make a really fast sound like tick tick tick...I even checked the fuse Tail 10A under the driver left leg in the car and the fuse is ok too...freaking frustrated
Old 07-29-2011, 12:32 PM   #13
PROX4x4
If it makes a fast tick tick then either the front or rear bulb is blown.
Old 07-29-2011, 01:16 PM   #14
Or the output of the flasher module is not getting to the bulbs. Besides checking the bulbs, wiggles the wires on the stalk connector while the flasher is on and see if it starts working.
Also, if you can snap pics of your connections in the under-hood fuse panel and at the stalk, we might be able to make more sense out of what is going on.
Old 07-29-2011, 01:46 PM   #15
06yarishb
Where is that flasher module and connector? Here is the picture of my fuse panel under the hood.
Old 07-29-2011, 01:28 PM   #16
06yarishb
still no luck...freakin yaris...I even take the bulbs from the right side put them on the left both front and back and all I hear is tick tick tick fast but no light...hopefully I didnt mess up any wiring while install that fog lights...I am beyond frustrating right now...
Old 07-29-2011, 02:15 PM   #17
06yarishb
damn somehow I just remove the haz fuse and replace it with the spare one now the signal works...my next problem solving is still the fog lights...:(
Old 07-29-2011, 02:23 PM   #18
Hang on - How did you connect the fogs under the hood? You don't have the two fog light wires installed in the connector next to the fuse puller?
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Fog Light Installation chrisj Cosmetic Modifications (Exterior/Interior) 39 03-12-2011 12:08 PM
Has anyone tried taping into the parking lights for fog light installation (safe?) YarisSedan DIY / Maintenance / Service 14 03-20-2010 05:49 AM
2009 HB fog light installation rbell DIY / Maintenance / Service 3 06-17-2009 10:16 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
