Old 03-20-2012, 08:21 PM   #1
walt101786
Drives: 07 Toyota Yaris Hatch-Back
wiper blades
i got some questions to ask....well first i must say...i need to replace my wiper blades cus they're wearing off....i know for a fact that they're size 14 on passenger side and 28 at the driver side...these are the standard replacement..my main question is that...if i do replace them with, let's say...rainnex lattitude one...can i put 16 on passenger side and 24 on the driver side? cus i wanna upgrade my wiper blades to better ones and the latitude ones only comes in 16 the smallest size...so is it possible to have 16 and 24??
walt101786 is offline   Reply With Quote
Old 03-20-2012, 08:24 PM   #2
Short and sweet, no. A 16 will sit on the A-pillar.
Some people have managed to successfully trim blades down. Works on some brands.
Search wiper blades. There is a HUGE thread on here about all kinds of options and theories.
Old 03-20-2012, 08:26 PM   #3
walt101786
oh...ok, well is there like any wiper blades i can get? like i wanna get the ones that latittude makes...but i am not sure if they make 14s though
Old 03-20-2012, 08:59 PM   #4
MadMax
MadMax's Avatar
You want frameless blades? Then I recommend the Bosch Marathons. You have to cut the passenger side one down, but it's easy using a Dremel; and they work great!
It's an easy process to cut one down, just remove the end caps, measure a few times to be absolutely sure you're cutting them down equally, and chop away! Re-attach the end caps and put 'em on!
Cheers! M2
Old 03-20-2012, 09:08 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
There are also many of us that have "upgraded" to the Honda wipers. I did that last summer and have been really happy. They work excellent even at speeds of 85 mph.
Old 03-20-2012, 09:42 PM   #6
josevenezolano
Drives: Toyota Yaris HB 2008
I have a Bosh 16 in my passenger side, it works ok.
josevenezolano is offline   Reply With Quote
Old 03-20-2012, 11:21 PM   #7
09sedan
Drives: 2009 yaris sedan
i went to dealer and bought the inserts using the factory blades, just replaced inserts.. they work like new!
09sedan is offline   Reply With Quote
Old 03-24-2012, 01:39 PM   #8
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
I have these on my Yaris for almost a year and they're okay. Good enough I got a set for the Camry as well.
http://item.mobileweb.ebay.com/viewi...id=45714258468
Old 03-24-2012, 03:38 PM   #9
403RS
#yyc
403RS's Avatar
Drives: BSP '07 RS 5dr LB
Anco makes a frameless 14" for the passenger side, I'm liking them so far.
http://www.ancowipers.com/products.html#p_contour
Wiper Blade - Contour
Front; Driver Side
Part: C-26-UB
Front; Passenger Side
Part: C-14-UB
Rear; Hatchback
Part: AR-12A
403RS is offline   Reply With Quote
Old 03-24-2012, 08:50 PM   #10
walt101786
i think i'll go with the anco contour blades...by the way...how much do they run up too?
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 07:54 PM
Wiper Blades futdechenes General Yaris / Vitz Discussion 44 06-27-2010 12:08 PM
Best Deal On Wiper Blades bobolinko General Yaris / Vitz Discussion 12 06-22-2010 03:15 PM
Replacement wiper blades fmicle General Yaris / Vitz Discussion 34 03-28-2010 10:58 AM
What kind of wiper blades? buyah123 DIY / Maintenance / Service 9 11-25-2008 06:25 PM
