Old 02-25-2017, 11:20 AM   #1
7:34pm
Drives: 07 Yaris
Axle and Final drive ratios
Hey, just got a OBD 2 wifi reader to play around with and I'm interested to know the axle and final drive ratios. I'm pretty sure what I've filled out is incorrect because it's telling me to shift way sooner than I should be.
7:34pm is offline   Reply With Quote
Old 02-26-2017, 12:57 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
That looks correct for a stock Yaris. When is it telling you to shift vs when you think you should?
Old 02-26-2017, 12:37 PM   #3
SirDigby
Drives: 2007 yaris 3 door
we have a double overdrive???
how funny!
Old 02-26-2017, 09:10 PM   #4
CrankyOldMan
Ha! 0.969 is almost 1:1. They also have a 1.031:1 4th in some related gearboxes, and a 0.725 5th.
Old 02-28-2017, 01:33 AM   #5
SirDigby
I know, but it's still overdriven. :) what has a 0.725?
Old 02-28-2017, 09:50 AM   #6
CrankyOldMan
The 07 Vibe/Matrix I got my C59 from. It had a really weird setup: 3.9 FD, 1.031 4th and 0.725 5th. I played with the different combinations on paper and found that the 0.969 was a better fit for the 1NZ. The 2ZR has such a completely different power curve that I may revisit my spreadsheets and see if a different gear set would be better.
OP: Do you have a tach? Most of the MT 2nd gen Yarii didn't come with one, and didn't even have a dummy light.
Old 02-28-2017, 09:21 PM   #7
SirDigby
can't the 5th gear be swapped out? I would think it would give a few more mph/kph out of 5th.
Old 02-28-2017, 10:29 PM   #8
CrankyOldMan
It can, but the tradeoff is that you're losing torque. Almost enough to make it not worthwhile for the MPG alone. I did it more for the RPM drop (and reduced engine noise) than anything.
Old 03-01-2017, 09:49 PM   #9
SirDigby
I said MPH, not MPG. my average MPG is 30.06...
Old 03-02-2017, 09:23 AM   #10
CrankyOldMan
Doh! My bad. Yes, you can potentially get more MPH, but you will hit the stock speed limiter around 180 KPH/112 MPH. The tradeoff of torque vs RPM is still there, and it makes 5th gear almost completely unresponsive to sudden throttle input at freeway speeds.
