Old 01-08-2012, 09:08 PM   #1
monicaownsayaris
Drives: 2010 Toyota Yaris (black)
Fixing broken headlight housing
A deer hit our Yaris the other day, but we hit its back end and managed to walk away with just some bumper cover cracks and random broken plastic along with a dent in the fender.
But the headlight housing came loose, and upon further inspection it cracked at all 3 bolt spots. The headlight is completely fine and works and all, but we can't re-attach it since each area on the plastic housing that gets bolted to the car cracked off.
So my question is, would I have to buy a whole new headlamp assembly or could i just replace the plastic casing that holds the headlamp with the bolt holes??? I really don't want to have to spend $60-80 just because some of the plastic ripped off.
monicaownsayaris is offline   Reply With Quote
Old 01-08-2012, 09:18 PM   #2
monicaownsayaris
To clarify these are the areas that cracked off:
So the black plastic has 3 areas that cracked off, but the actual headlight is ok
Old 01-08-2012, 09:44 PM   #3
You can buy replacement tabs that attach to the headlight with screws from your local dealer (If you look where the tabs broke there are actually places for the screws to attach). They are about $10 each, but a replacement headlamp is typically way more than $30.
Old 01-08-2012, 11:01 PM   #4
monicaownsayaris
Yea $30 for 3 tabs is MUCH better than $80 for the headlight assembly I found on ebay. And it'd be such a waste since the actual headlight aside from the tabs is completely ok.
However I took a look at it and I'm not sure where I'd screw the new tabs in. On 2 of the broken tabs, there are these 2 holes sticking out (the first picture) so that looks promising. But the third I can't guess as to where I'd screw it in (second picture). Maybe it'll make more sense when I buy the tabs or when I look again during daylight, but at least it's not obvious to me now.
and
Old 01-09-2012, 10:12 AM   #5
Klink10
Klink10's Avatar
Sorry about your misfortune and glad all are okay. I knew I bought those headlights off another member for a reason.
Old 01-09-2012, 10:35 AM   #6
and
There are only two repair tabs, so apparently Toyota doesn't consider the top one to be critical.
Old 01-09-2012, 03:58 PM   #7
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
CT
i think you mean the tab where the fender/bumper meet
OTA'sTOY is offline   Reply With Quote
Old 01-09-2012, 04:08 PM   #8
Originally Posted by OTA'sTOY View Post
CT
Correct - It's actually the bottom, not top one.
Old 01-10-2012, 12:55 AM   #9
monicaownsayaris
Yes - it's the one by the fender that doesn't have those holes. So I guess I can repair 2 of the tabs then
Old 01-10-2012, 07:41 AM   #10
Correct.
Tags
cracked, deer, headlamp, headlight, replace
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 05:13 AM
Painting headlight housing black need diy.. YarisSedan Cosmetic Modifications (Exterior/Interior) 5 12-12-2011 11:24 PM
DIY Projector/HID (Liftback) PETERPOOP DIY / Maintenance / Service 46 08-30-2011 11:36 AM
WTB 09 or 10 Headlight housing, both Slick Willing to Buy by private party 0 10-03-2010 08:02 PM
WTB stock hatchback headlight housing GTA!! marcus Willing to Buy by private party 3 07-06-2010 07:30 PM
