Old 01-16-2012, 03:11 AM   #1
lcastrob
Drives: hb
help with fog install
hi all
i bought a kit from microimage, did the engine bay part ok but i dont know how to proceed in the interior and will really appreciate your help
the relay is installed in the right place
the switch has 3 cables coming out as the picture.
what i need to do with these 3 cables.???
lcastrob is offline   Reply With Quote
Old 01-16-2012, 02:20 PM   #2
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
http://www.microimageonline.com/down...ts_install.pdf
http://www.microimageonline.com/down...h%20Wiring.pdf
OTA'sTOY is offline   Reply With Quote
Old 01-16-2012, 03:16 PM   #3
lcastrob
Drives: hb
i am using those but im confused... please excuse me as i am rookie on this things
b. For the fogs to turn on with the parking lights, low beams or high beams connect the
outside red wire to pin 3 and the green wire next to it to pin 13 of Connector D4,
which is the headlight stalk connector
red wire? i only have one orange... and it has a strange connector that i dont know how to use.
i am supposed to cut the wires? or remove one wire and replace the other?
the black one has a different connector it looks like a ground you will connect to a bolt.
Old 01-18-2012, 04:57 PM   #4
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
PAGE #4 red wire would need to be extended and routed up to steering column for foglight to be able to turn on with marker,low light and high light
Old 01-16-2012, 05:50 PM   #5
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
page #8 :
your green wire would be yellow in the hareness pic
your orange would be red
your black is the ground in page#10
Old 01-16-2012, 10:15 PM   #6
lcastrob
Drives: hb
thanks i think i almost got it...
1. remove pin 3 cable from D4 connector
2. connect the cable i just removed from D4 and connect it to my orange cable
3.connect my green cable to the pin 3
4. connect ground cable
am i correct?
i found the 2 set of instructions a litle different... did i receive an outdated switch?
woulndt i be missing the connection for the switch light?ç
also i would like help on how to remove the pin from D4 connector i tried but i was not able and i was afraid of breaking it.
i appreciate all the help at this moment i have my fogs in the bumper but no lights!
Old 01-18-2012, 04:43 PM   #7
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
am i correct?yes
i found the 2 set of instructions a litle different... did i receive an outdated switch?instuctions are good just the kit wiring changed colors
woulndt i be missing the connection for the switch light?çare you talking about the switch that comes with the kit?
also i would like help on how to remove the pin from D4 connector i tried but i was not able and i was afraid of breaking it.get yourself a paperclip and file the end into a angled tip use it to separate the terminal wire from connector
Old 01-17-2012, 08:27 PM   #8
lcastrob
Drives: hb
can someone confirm? i think im going to try tomorrow...
Old 01-18-2012, 05:33 PM   #9
lcastrob
Drives: hb
thanks a lot man! i will try it and i hope soon ill post a success picture of my fog lights!!
Old 01-19-2012, 08:29 PM   #10
lcastrob
Drives: hb
omg !!!
today i came back from work, open everything... had my paper clip at hand and wasnt able to remove the pin...
im afraid of pulling too hard and leaving the connector but removing the wire...
any tips? i think i will have to ask a friend who has more experience on cars...
Old 01-19-2012, 09:45 PM   #11
omg !!!
I prefer an Xacto knife blade to a paperclip (if I don't have a proper pin popper). The tab that you are lifting is only in about 1/4". lift the pin lock tab and insert the blade in as shown below. I like to angle the blade towards the metal of the pin to get the blade to go on the correct side of the plastic tab (it is very easy to go above it, which makes it impossible to pull the pin). Once the blade is in position, lift the tip away from the metal pin and you will hear a slight click from the plastic tab. At that point the pin will easily slide out the back of the connector.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 06:15 PM
How to choose and install HID on FOG light charleschia1986 Cosmetic Modifications (Exterior/Interior) 18 12-20-2010 10:45 PM
Fog Light Install - HELP GrimlockGT Cosmetic Modifications (Exterior/Interior) 1 03-19-2010 05:58 PM
