Drives: 2000 yaris Join Date: Mar 2012
Freetronic gearbox question
Hi guy`s
![]() I have a 2000 Yaris with the Freetronic gearbox. Works great, I bought this as a 1st car for my sons 21st. This is the problem: When I turn off the ignition theres a buzzing which comes from the direction what looks like a solenoid on the right hand (passengerside) side between the engine and the battery. In the picture its just behind the brake fluid reservoir which you can see. If I take off the lid of the fuse box and remove the brown relay it stops....putting it back in it starts again but if I start the engine and then turn it off......I can then put the relay back in its place without the buzzing starting up. It has something to do with the gear selection because it wont go into gear without this relay and ive had a look at a couple of scrap cars which are manual transmission and they don't have the same relay or the (what looks like) solenoid etc. Edit: It doesn't do this all the time.....but most of the time. Any idea`s? TIA. |
| Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 12:59 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| Where is my oil leak coming from? The Gearbox? | MarkBond | General Yaris / Vitz Discussion | 1 | 08-25-2007 10:31 PM |
| Question about 2 kinds of TRD springs & rear strut bar | Astroman | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-18-2007 05:44 PM |
