![]() Drives: 2008 Yaris Join Date: Nov 2009
Horsepower in a can
Just wanted to pass some information along. Was at the Parts store today and happened to see some CRC Mass air flow cleaner and thought I would give it a try since my car has almost 70k figured it couldn't hurt. The bottle said 4-10whp and I doubt I got any of that but, wow did it make a difference in throttle response and overall the car seems to run smoother. Thought I would just put this information out there.
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
I did mine last week and it was night and day differance...they do indeed get dirty,don't know how often they should be cleaned but I am at 60000 miles and this was my first time cleaning it...lol
Same here the directions recommend every time you clean or change the filter
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
bout how much that run you? I got 91k on mine so i'm bettin it'd do miricles to mine
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
Drives: yaris Join Date: Jan 2011
this is the only horsepower in a can that is actually valid
the MAF will build up contaminants indefinitely and must be cleaned on a regular basis. the buildup is from engine shutdown, and the last crankcase vapors coming out of the PCV valve float around and deposit in the MAF. gotta get that crud off |
My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
I've got some MAF cleaner sitting in my garage, only at 20k on my Yaris but shouldn't hurt to clean it anyway. just hadn't thought of it yet.
![]() ![]() ![]() Drives: 2009 Toyota Yaris Join Date: Jan 2009
any DIYs for this ? :D
I got a ride in Garms' Yaris and got on a plane within 24 hours of each other.... his yaris was faster! I bet if he put wings on it he could get passed all that L.A. traffic! |
^what he said. spray it off, put it back on.
Also I always unhook my battery.....I seem to always short something out.
Cleaned mine at 60K miles. Didn't notice a damn bit of difference.
@bkndacn, remove MAF and spray with product. Reinstall MAF. http://www.microimageonline.com/foru...ir-flow-sensor
Not quite a noob
having the ignition off should do the trick for that no?
yes but technically you should disconnect battery
I have pulled toyota MAFs about 20 times and never disconnected battery and never had a problem -except- when the reason I pulled it was a MIL...need to reset the ECU if the MAF popped a MIL for best results after reinstall of the MAF |
I think the can was around 10 bucks
I bought mine the other day at it was lik $8 at O'riley's
![]() Drives: 09 Yaris Sedan Flint Mica Join Date: May 2009
Hello YW I did this today and wow. Just rolled 53,000 miles. Idle is smoother mpg is back to normal very happy! Best eight bucks i have spent on my baby.
![]() Drives: 2010 Yaris S HB Join Date: Nov 2011
Hm. I know Toyota isn't the best about their MAF sensors getting crud on them (3.4 v6 anyone?), but I was dubious of this. I may have to try it. I expect it's even more pronounced when you have a high-flow air filter with oil in it.
I've got a K&N and when I took out the MAF, not only was the intake tube clean and dry, the MAF sensor didn't look dirty at all. I still gave it a shot of cleaner and it does seem as if the engine runs slighty better. Could be a placebo effect though.
keckbot
Drives: 2007 Blazin' Blue Liftback Join Date: Aug 2011
Did this the other day after I got a CEL code for the sensor. I have noticed a great increase my ability to pick up speed a lot faster, although at the same time I also removed my 60/40 seats. Either way, I highly recommend.
| Dynotest synthetic oil increases horsepower | YarisSedan | Performance Modifications | 3 | 04-10-2009 02:31 AM |
| What's the best way to add 5 horsepower? Giant Micro Image stickers, of course! | 33OH | Photo-Video-Media Gallery | 42 | 03-07-2009 12:34 PM |
| Q HORSEPOWER SYNTHETIC $18 for 5Qt Jug | TheSilkySmooth | DIY / Maintenance / Service | 11 | 02-25-2009 11:47 AM |
| New way to gain horsepower!!!! | marcus | Performance Modifications | 5 | 05-07-2007 10:35 PM |
