Lift back pneumatic lifters
I have noticed that the pneumatic lifter joints on my hatch back are becomming a lot mor stiff and creaking more these days. Any suggestions on lube for these if i take them off..WD40? Anyone else notice this on their car?
Yep, happening to my 08 as well...
The gas struts are affected by the cold and will not work as well when it is really cold.
You should not lubricate the shaft (particularly with WD40, which will destroy the seals). Gas struts have oil within them that both dampens them and self lubricates them. You can wipe off the shaft if it is dusty, but according to the manufacturers you should not lubricate them. The ball joints at the ends can and should be lubricated though.
Thank you. It does sound more like the ball joints at the ends. I'll lube them this weekend. Thanks again.
| My yaris lift back SQ install | cm_ls1 | In Car Entertainment + Electronics (audio / video / alarm) | 61 | 12-21-2010 10:39 AM |
| 2008 S Lift Back | k27 | General Yaris / Vitz Discussion | 6 | 09-16-2007 10:48 AM |
| So we just came back from TRD Thailand... | eTiMaGo | Performance Modifications | 28 | 03-21-2007 05:52 PM |
| back seat | KSIbucky | General Yaris / Vitz Discussion | 10 | 05-30-2006 12:54 PM |
