Old 07-06-2012, 12:13 PM   #1
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
Where is the ABS fuse located?
im trying to find the ABS fuse for my 07 yaris but i dont have the manual and i dont see it in the diagram does anyone know where the ABS fuse is located?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 07-06-2012, 07:50 PM   #2
BLH
Drives: 2007 Yaris Sedan
There is a sticky thread at the top of this section. Where you may still find links to the 2007 Maintenance Manuals.
The Brake Control Section and EWD Section shows two main fuses. Both are in the fuse box in the engine compartment. A 50 Amp ABS1/VSC1 and a 30 Amp ABS2/VSC2 fuse. If you look at the cover for the fuse box. It has a fuse layout of where the fuses are.
They also show a few others that could effect the ABS but would also effect other systems.
BLH is offline   Reply With Quote
Old 07-07-2012, 09:33 AM   #3
ijose 845
ijose 845's Avatar
if i pull the 2 ABS/VSC fuses will that affect anything else rather than my abs? what does VSC even mean
Angry Bird Crew #1
Old 07-07-2012, 10:28 AM   #4
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
VSC - vehicle stability control
Toyota Owners Official Website - download your owners manual right there.
30A Power Fuse Instrument Panel Location? Kioshi DIY / Maintenance / Service 16 03-31-2013 07:53 PM
Fuse Fix bronsin General Yaris / Vitz Discussion 4 12-18-2011 03:05 AM
Pulled Abs fuse KevD Performance Modifications 18 09-10-2011 02:12 AM
What's with ABS? jgag123 Canada 9 01-01-2009 07:04 PM
ABS questions ppk Performance Modifications 11 12-04-2008 03:22 PM
