Old 02-25-2007, 10:37 AM   #1
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
wat r things to do when changing from 15 to 17?
what adjustments should I make?
tires are 205 45 17 with 17-7.5
-- Blen
Old 02-25-2007, 11:14 AM   #2
there should not really be anything to adjust, but get your alignment checked just in case!
Old 02-25-2007, 02:47 PM   #3
Blenjar
Blenjar's Avatar
alignment it is!
-- Blen
Old 02-25-2007, 02:50 PM   #4
Blenjar
Blenjar's Avatar
I'll post pic when I get them this week...by like around thursday or friday...how much is it to have sum1 install them for me? what is the price range so I can go hustle them down for a lower price.
-- Blen
Old 02-25-2007, 04:20 PM   #5
OK Yaris
Drives: 2007 Liftback
-- Blen
If you can get them mounted/balanced for $10/wheel, you're doing good. If you didn't buy the wheels/tires from the shop, they may charge you a little more.
I always shop around for someone who mounts aftermarket wheels everyday. Having the job done correctly and rolling away with no scratches or gouges on my wheels means more to me than price.
OK Yaris is offline   Reply With Quote
Old 02-25-2007, 05:13 PM   #6
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
are you dropped? or on stock springs? im runnin a 17x7 wheel with a +42 offset. im on 205/45/17 tires and with tanabe nf springs i have minor rubbing on good sharp dips, i think this could be corrected with a stiffer set of aftermarket shocks....
your case may be different but im just throwing up the warning. i think i may go with a 205/40 along with the shocks and i know i wont have any problems.....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 02-25-2007, 06:23 PM   #7
Blenjar
Blenjar's Avatar
No drop here...mine are 42 offset too.
Will I rub with no drop?
-- Blen
Old 02-27-2007, 07:21 PM   #8
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
I was told that from going to 15 to 17 an aliment is necessary. Something about adjusting the front toes.
My question is out of place but how do you find the offset to your rims? Are they listed on the rims themselves?
eijikikimaru is offline   Reply With Quote
Old 02-27-2007, 07:29 PM   #9
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
i heard that when you do balance and rotate you need to bring it to a place that they do high speed balance and rotate it's cost around $100 dollars for that. So when you ride at high speed like 80 and up your car will not move around or kindda like jipperryy ( shaking) is it true?
jamal1984 is offline   Reply With Quote
Old 02-27-2007, 10:22 PM   #10
dansides
dansides's Avatar
Drives: 07 3 dr
you may look at the hunter gsp 9700 balancing system ck their web site i understand that tirerack a discount tires use this and is considered one of the best my discount store balanced my yaris an has no vibration at any speed also they offer free spin balancing an rotation for the life of your tires may wk for you
dansides is offline   Reply With Quote
Old 02-27-2007, 10:36 PM   #11
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I can barely read your post. Remember to capitalize the first letter in a sentence and end it with a period.
PetersRedYaris is offline   Reply With Quote
Old 02-28-2007, 04:30 PM   #12
Blenjar
Blenjar's Avatar
lmao, sum1 just got owned
http://dansides.justgotowned.com/
-- Blen
Old 02-28-2007, 06:22 PM   #13
dansides
dansides's Avatar
Drives: 07 3 dr
Yes teacher will try and do better next time just doing it in a hurry ... I was THINKing most people know where the .... ,,,, ???? //// """" should be. From now i will do better . I think i will go set in time out now.
Old 02-27-2007, 10:50 PM   #14
Black Yaris
der Zeck
Black Yaris's Avatar
no alignment is needed when changing wheel/tire size... Changing your wheels in noway magicly adjust your tie rods... and if you are wanting to run a 7.5 wide wheel I would go to a 215/40R17, unless you like the stretched look then go 205's. Also with a +42 offset and a 7.5in wide wheel you most likely will rub,but only on a full lock turn.
Old 02-28-2007, 03:37 PM   #15
MrJester
Drives: homo
Alright I need a newb guide to tires and what not. Like the sizes and what all they mean and what not. Cause I read all this on here and really have no idea what everyone is talking about. Is there such a post already if not could someone help me out a bit. Thanks :)
MrJester is offline   Reply With Quote
Old 02-28-2007, 04:35 PM   #16
SailDesign
Drives: .
Here is the spreadsheet I use to play with sizes. it SHOULD oughta be self-explanatory, but feel free to ask.
Steve
Things you would like to see? Chaad32 General Yaris / Vitz Discussion 46 04-15-2009 08:01 AM
Changing Headlight Bulb Tutorial RSboyz DIY / Maintenance / Service 29 03-15-2007 01:35 PM
Are you changing your oil at 5k mile interval recommended by Toyota? Yaris_Fan DIY / Maintenance / Service 24 01-30-2007 11:54 AM
Wat is different between DF 210 and Nf 210 springs and which one it better?? mariosuper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-16-2006 01:39 AM
Changing to 60/40 seats? NickNickNick General Yaris / Vitz Discussion 1 05-14-2006 04:08 PM
