Old 01-08-2013, 03:25 PM   #1
discomark10
Drives: 02 Yaris 1.5 T-sport
Unhappy Induction kit running issue
Hi guys,
I installed an iduction kit to replace the standard air box today.
It started fine, idle seemed ok, but when I took it for a test drive it was very slugish and sort of bogged down a low/med revs. Seemed to run a bit better with higher up the revs.
I ended up putting it back to standard shortly after as I needed to use it and it ran fine so the maf must be ok.
Any idea's why it ran like that?
Thanks
discomark10 is offline   Reply With Quote
Old 01-08-2013, 08:56 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
You could try putting your new intake back on and disconnecting your negative battery cable for about ten minutes so that your computer will forget the old stock air box operating parameters, and learn the new parameters of your intake.
Old 01-08-2013, 11:47 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
What's the inside diamater of the pipe on the new intake? If it's any bigger than stock the MAF will read less air passing by and give less fuel making LESS power.
Old 01-09-2013, 10:13 AM   #4
^ This. You never answered the question about inside diameter. What kit are you running?
The ECU is very particular about air passing the MAF. Deviate from 2.25" inside diameter on the pipe and you'll typically run into problems.
Old 01-09-2013, 12:45 PM   #5
discomark10
ill have to check it out tomorrow
Did you disconnect the battery when installing, so your ECU can relearn with your new intake?
yes but only for a couple min, will be tryng it tomorrow also
Old 01-09-2013, 02:42 PM   #6
discomark10
just checked, its 2.32" (59mm) rather than 2.25" (57mm) .... (25.5cm2 over 27.3cm2)
Only a tad bigger, wouldn't Imagen that small a difference will cause a problem would it?
Old 01-09-2013, 04:23 PM   #7
Bluevitz-rs
2734mm2 = 59mmŲ
2551.75mm2 = 57mmŲ
That's a 7% jump with no additional fuel.
Old 01-10-2013, 10:08 AM   #8
discomark10
So today I had another go at sorting it out. Reset the ecu as sujested. It did run better but still no where near right.
This seems to be the problem, I made a restrictor to put inside to reduce the ID of the tube and it helped allot! I still think it was down on power a lil bit.
Ive put it back to standard untill I can remake it with a smaller ID tube or of course get a premade one.
Does anybody know what size ID the aftermarket one is?
Old 01-09-2013, 12:53 AM   #9
Could be one or both of what was mentioned above.
Disconnect the negative terminal on the battery. Pump your brakes until it becomes stiff. Let it sit for like 10-15 minutes. Reconnect the battery terminal, and start your engine and let idle for ~15 minutes. Do NOT step on the gas or anything, just let it idle. That should help.
Old 01-09-2013, 05:39 AM   #10
discomark10
Cool ill give it a go, what does pumping the brakes do?
Old 01-09-2013, 09:30 AM   #11
Bluevitz-rs
Nothing. Because as soon as you open the door the dome light turns on. And drains any residual charge in the electrical system.
Old 01-09-2013, 09:43 AM   #12
discomark10
Man, all the fangled technology! Give me an old Land Rover any day ;)
Old 01-09-2013, 12:58 PM   #13
Just a little extra to get any and all residual charge out. I've had better luck with pumping my brakes than not.
Old 01-09-2013, 11:38 AM   #14
Old 01-09-2013, 04:02 PM   #15
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
what brand intake did you get?
OTA'sTOY is offline   Reply With Quote
Old 01-09-2013, 05:03 PM   #16
discomark10
I fabricated it myself as they cost the equivalent of around $250 here...
I'm going to have to either fix or remake it, if resetting the ECU reset fails.
It only cost about $15 to make out of stainless, so a bit cheaper!
Old 01-10-2013, 12:40 PM   #17
Bluevitz-rs
Old 01-10-2013, 01:04 PM   #18
tooter
play every day
tooter's Avatar
Hey disco, can you post a pic of your intake? Maybe if we can see it, we can help you figure out how to make it work. I admire that you're adventurous enough to try to make one up. I just measured the outside diameter of the two intakes I have:
Weapon R 57mm
Simota 59.5mm
Both work fine, and the difference might be the wall thickness of the tubing. I'll need to disassemble them to get the more accurate inside measurements. How your MAF sensor is positioned relative to the center of the tubing is important. Maybe spacing it up or down will help. I'm taking the intakes apart today to get a better fit on the throttle body so I'll take some measurments and let you know.
Greg
WTB Forced Induction kit JohninVT Willing to Buy by private party 5 11-12-2012 03:24 PM
how to fit induction kit to my p1 daveyboigt Performance Modifications 0 10-21-2012 05:06 PM
Induction air filter on yaris diesel - good or bad?!?! Ziishan DIY / Maintenance / Service 3 10-20-2012 08:43 AM
VIS jdm rs body kit Dperry Cosmetic Modifications (Exterior/Interior) 2 05-06-2012 11:00 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 08:42 PM
