Old 09-07-2012, 07:52 AM   #1
cougar65
cougar65's Avatar
Drives: 2010 yaris 5door
Why is the 2012 rated 2mpg higher than 2011
And below. Is it a tire difference or did the body change effect the aerodynamics?
cougar65 is offline   Reply With Quote
Old 09-07-2012, 03:12 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Probably cuz they have more prius' they rather sell you. Before there was only one...so they rated the yaris low mpg to try to get people in the prius.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-07-2012, 03:44 PM   #3
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
from what i've read, it's due to better aerodynamics...
b20vteg is offline   Reply With Quote
Old 09-08-2012, 02:08 AM   #4
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Quite likely, b20vteg. It doesn't take a lot to change the aerodynamics, and the results are often dramatic. All one has to do is follow F1 to learn that...
Old 09-12-2012, 10:49 PM   #5
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
It just might be the 2012's new exhaust manifold design...
Old 09-12-2012, 11:48 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
Wow that is different!
Old 09-13-2012, 03:24 AM   #7
Yaristeve
Drives: 3-door hatch
Oooooooo... Will that retrofit as a straight bolt on to the 2011? In the Miata world, a popular mod is to retrofit a 2001 tubular exhaust manifold for the 99-00 cast iron manifold. Works about as good as an aftermarket header but looks bone stock to the inspectors.
Old 09-13-2012, 01:16 PM   #8
tooter
play every day
tooter's Avatar
Yes, it will.
I know because I had replaced it with a Weapon R header that was listed for 2007-2011 models and it fit perfectly.
Old 09-13-2012, 05:55 PM   #9
Yaristeve
Yes, it will.
Hmmmm... You "had" replaced it? Do still have it? For sale?
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 10:20 PM
2011 vs 2012 beebosaur New YARIS Purchase Forum 11 08-27-2011 09:37 AM
First Drive: 2012 Ford Focus Kal-El Off-topic / Other Cars / Everything else Discussions 18 02-25-2011 06:41 PM
2012 Vitz from the 2011 Tokyo Auto Salon CTScott Third Gen Yaris General Discussion 14 02-10-2011 09:06 AM
