Drives: Toyota Yaris 1.0 litre Join Date: Aug 2012
Radio/CD suddenly dead
I have a 2007 Toyota Yaris and the unit has suddenly died. The problem is not fuse related because the dimmer light which is on the same fuse is working ok. Any Ideas?
The dimmer fuse is just for saving the radio station memory when power is off. The ACC fuse powers the main functions.
#3 | |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
I have a question to that end... My Scion XD stereo looses all the presets when the battery is removed, but remembers EVERYTHING when I disconnect the power cable (battery power still live) from the unit and remove the head unit and store it, even for a year or more... What's the goings on here? I cannot understand why this happens, but it does. Did it more than once, and on more than one car. Thanks! |
#4 | |
#5 | |
Bob
I, too thought I was "losing it" so I had to do it 3 times and sure enough, each time the results were the same. I was thinking about the diode, but have not had the motivation to getting into the dash again. It just might be the same with the Yaris radios too... |
#6 | |
Bob
OK, heres thescoop:
Since we started the discussion, I got enough motivation to jump in and try the installation of a diode to the 12v Constant supply wire. I had considered a switch or diode and went with the diode to have less hassles in the future. I cut the constant supply feed line and soldered in a small rectifier (3 amp) and heat shrinked insulation on it. Installed the radio, and all the presets still were intact. removed the battery and serviced both ground and positive terminals which took about 20 minutes. Waited about another 15 minutes and re-connected the battery terminals. The head unit's presets were still intact! I am sure there is a cap in the head unit that keeps the volatile memory alive during periods of disconnection. I cannot understand why Scion had not intalled a 75 cent rectifier in the harness to make life so much easier for it's buyers! If the Yaris has no facility for this, an installed cap and diode would surely do the trick! All is now good, and thanks CT- for kicking me over the edge to do the mod! The Band side (Cathode) goes to the HU and the other end to the wiring harness.
| HELP, CAR SUDDENLY GOT LEAN | Faraz_Shaikh | Forced Induction Forum | 26 | 03-31-2011 08:54 PM |
| HELP, my car is completely DEAD!!! | Arlyarlz | General Yaris / Vitz Discussion | 18 | 07-19-2009 04:03 AM |
| 3rd 360 dead, do I move to PS3 ? | Dbeau | Off-topic / Other Cars / Everything else Discussions | 18 | 04-27-2009 09:04 AM |
