Old 08-01-2007, 02:11 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
any computer wizards in here. HELP!
ok i built a computer unfortunetely i got the old xp pro sp1.. loaded it but maximum hard drive read was only 120-130 gig..which i know is the sp1 max.. now i loaded service pack 2..now how do i read the rest of my 320g hard drive.?? anyone.. thanks!
Old 08-01-2007, 02:14 PM   #2
hmmm won't be easy, AFAIK you'd need to either reformat the whole drive, or you could create a new partition (go to control panel - administrative options - computer management - disk management).
Or you could get a program like Partition Magic or similar that can easily resize partitions.
Old 08-01-2007, 02:18 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Yeah, parition magic would be the way to go
Old 08-01-2007, 02:20 PM   #4
marcus
toyota
marcus's Avatar
thanks astro!
thanks, ill check the partition magic.. but i always thought it only partition the current formatted hdd which is 120G but i got 320g drive im missing 200g..
Old 08-01-2007, 02:18 PM   #5
marcus
toyota
marcus's Avatar
well im tryin not to reformat..coz i got some file already set up on it.. i can try disk management but since i format fr xp sp1 120g..would i see the rest of the memory since i got sp2 loaded? and partition them..thanks etimago!
Old 08-01-2007, 02:24 PM   #6
yeah basically only 120gb of ytour hard drive has been assigned to a drive letter, so you can use partitionmagic to stretch that to the full capacity. Or like I said, you can create a new partition in the extra space, it's not a bad idea either, to keep most of your files, downloads, music, whatever away from your main windows partition, that way when you need to reinstall windows next time, you'll have an easier time carrying stuff over.
Old 08-01-2007, 02:29 PM   #7
marcus
toyota
marcus's Avatar
thanks guys i will try these.. any other option feel free to drop it in here.. might help other people as well..!!
Old 08-01-2007, 02:38 PM   #8
marcus
toyota
marcus's Avatar
partition from c to x.. wow thats alot..
Old 08-01-2007, 02:41 PM   #9
sherryberry
sherryberry's Avatar
Drives: 07 Blazing Blue Yaris
Send a message via AIM to sherryberry Send a message via MSN to sherryberry Send a message via Yahoo to sherryberry
holy cow, eTimaGo, that's a LOT of partitions. did you just do that for fun? or was there some kind of actual reason for doing so?
Don't Milk the Cat!
-Said by me during a game of Cranium.
sherryberry is offline   Reply With Quote
Old 08-01-2007, 02:51 PM   #10
for fun, and just to see if it would work... and back then it was only like a 1GB hard drive, so the partitions (except for C:) were just tiny
Oh and back then it had to be all done through DOS, very slowly...
Yup, I'm a certifiable geek.
Old 08-01-2007, 02:58 PM   #11
sherryberry
HAHAHA i'm guessin that pc's not around anymore. or is it still all there?
oh and marcus, have you gotten the issue solved yet?
Don't Milk the Cat!
Old 08-01-2007, 03:05 PM   #12
marcus
toyota
marcus's Avatar
not yet sherry berry..im at work ill try it when i get home..
Old 08-01-2007, 03:10 PM   #13
marcus
toyota
marcus's Avatar
ill check that as well vasilios!! thanks bro!
Old 08-01-2007, 03:47 PM   #14
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
I would use disk manager to create a D: partition for the rest of your drive and use it for bulk storage. That way if your boot partition ever gets funked up, you just wipe out that partition and reinstall. Your data on D: is never touched.
Word of warning: If you ever reinstall, pay attention to the drive letters the OS assigns. I've seen XP take a partiton that was my D: and switch it to my C: when I reinstalled. Caused me to do another reinstall to fix it.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 08-01-2007, 04:00 PM   #15
marcus
toyota
marcus's Avatar
dang too much info marcus getting headaches...!!
Old 08-01-2007, 04:01 PM   #16
marcus
toyota
marcus's Avatar
i will keep everything in mind...atleast u guys helping not to run into trouble..kewl thanks guys and gals!!
Old 08-01-2007, 04:10 PM   #17
nsmitchell
nsmitchell's Avatar
FYI - Type compmgmt.msc to access "Disk Management" from an XP commandline.
PS - I don't know your level of knowledge.
Get YarAss in gear!
RIP - Casey Tatum
Old 08-01-2007, 04:52 PM   #18
marcus
toyota
marcus's Avatar
well i learn as i go on...1 0ut of five being the highest im in the middle
building the computer from scratch taught me a thing or two...
asus p5b vm se board
intel core 2 duo e6320 1.8ghz 4mb cache 1100 mhz fsb
ocz 6400 800 mhz 2g ram
lg dvd rw/cd/dvd
320 seagate hdd
500 watts power supply
hanns 19 wide screen lcd monitor
200 watts sorroundsound received ( entertainment system)
upcoming: 7900 gs oc video card
My Home Computer Nutzoids Off-topic / Other Cars / Everything else Discussions 38 05-02-2007 09:51 PM
Computer webmaster In Car Entertainment + Electronics (audio / video / alarm) 54 03-13-2007 07:19 PM
