#1 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Digital Fuel Adjuster? by JayCar Electronics
![]() https://www.jaycar.com/productView.a...5385&URL=index Quote:
Does anyone have any experience with it? |
#2 | |
Looks like you need an archaic RS232 cable and a this Hand Controller:
http://www.jaycar.com.au/productView.asp?ID=KC5386 ![]() Quote:
I don't have any experience with this device, but do with AEM F/ICs. Reading that Prius article, it really doesn't appear that they were successful in their use of the device.
Also, Since it requires the separate controller for configuring it, the cost for it is $140. I have purchased AEM F/ICs for as little as $200. The website does not provide access to to manual for it to see if any cabling is included (The F/IC includes a harness, which would run about $45 to purchase separately).
#4 | |
$45!? Wouldn't I need the Boomslang Plug and Play Harness for AEM FIC that runs $475 also? |
Not necessarily. You can hard wire the F/IC with the included harness. The boomslang makes the process easier, but is definitely not required.
How many hours of labor would a shop charge to wire in the F/IC?
I would think that a shop would hit you for 4 to 8 hours, but doing it yourself shouldn't take more than an hour or two, as there are only 22 connections to the ECM connectors. The hardest part is convincing yourself to make the hole in the firewall to run the harness through.
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
