![]() Drives: Yaris TS NCP13 '02 Join Date: Jan 2013
Rims size question
Hi everyone, I'm absolutely a tires/rims size newbie! be kind with me!
![]() I use the stock tires size (185/55/R15) and wheel spacers (16mm front/20mm rear) on my '02 TS. I'd like to buy a set of Rota RB, 15x8 4x100mm ET30, can I fit those on my car without rolling the fenders? thank you so much!
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
Is your car lowered
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
Thanks everyone for your answers!
yes it is, TA Technix shocks+springs -40mm
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
http://www.1010tires.com/WheelOffsetCalculator.asp
Extend 31 mm front and 27mm rear that is not bad at all but drop and tire size is gonna have a lot to do with it. |
#5 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
![]() ![]() And I understand your situation, because I also was blindsided by the width/offset unknowns so I stayed closer to stock and am running 15X7 +35's and 195/65 tires with no rubbing at stock height. the front wheels are just barely under the edge of the fender so if the car was lowered, it would likely rub. This is because Rota's have a wide machined edge outside of the spokes like the old fashioned wheels used to have. Thst's why they look so distinctive. ![]() Notice that the new style front wheel drive rims usually have none and so more easily tuck under fenders on lowered cars. I did discover that with the +35's I needed to add 5mm spacers to allow the front wheels to clear the disc brake calipers. If you run +30's that shouldn't be an issue, because they get the wheels to position closer to the center of the vehicle by machining the inside surface that bolts onto the hubs. That's where the reduced brake clearance comes from. Please post pics when you get them!
Not a fan of those rotas. Again its all opinions. I did not have that issue with my rota gt3's and they are a +40 offset. It must be an RB only issue. Also keep in mind op has an 2002
#7 | |
play every day
Enkei also made that same style in the 1980's. |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
play every day
Wow... they do.
Oooh... nice! ![]()
| Question about header outlet size and system diameter | Shinare | Performance Modifications | 10 | 12-10-2010 09:27 PM |
| Best replacement tire size for stock rims? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 12-10-2010 04:27 PM |
| Tire Size and FE question | GMKing | Fuel Economy Forum | 8 | 09-01-2009 09:20 PM |
| Can I use stock tires on these 15" rims? | songa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 02-18-2009 07:11 AM |
| Coolant Hose Size Question | vasilios | DIY / Maintenance / Service | 2 | 06-27-2007 09:45 AM |
