Old 04-10-2013, 10:31 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Maintenence Required light won't turn off...
On my 2012, the Maintenance Required light started blinking as the 5,000 mile mark on the odometer approached, and then once past 5,000, it has stayed on ever since. So I know that it is a time triggered event. I have an OBDII code reader and there are no fault codes stored. While the reader can erase codes, it can't turn off the light.
Does anyone here know how to turn that light off.
Old 04-10-2013, 10:36 PM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Same as previous generation:
set the display to trip A.
turn key off.
Press and hold the trip button and turn the key to II (engine off) in the ignition.
the display will blink with dashes down to oooooo and the "maint. light" will be blinking as well.
once it returns to trip A release the button.
That is it.
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-10-2013, 10:55 PM   #3
tooter
play every day
tooter's Avatar
turn key off.
That is it.
Thanks, shroom!
Your directions worked perfectly.
Old 04-10-2013, 10:40 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
the real question is did you actually change the oil before wanting the light to go away :P
Old 04-10-2013, 10:50 PM   #5
tooter
play every day
tooter's Avatar
I've done two changes in less than 5,000 miles as I'm anal about clean oil.
Old 04-10-2013, 10:56 PM   #6
Golddeenoh
Golddeenoh's Avatar
^ you just had to love on it right :P
Old 04-11-2013, 09:24 AM   #7
Shroomster
Shroomster's Avatar
You're welcome!
Old 04-11-2013, 10:31 AM   #8
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
As I understand the first oil added to the engine when brand new is designed to aid in breaking in the engine. Changing the oil early is not going to help the break-in process. It is also a huge waste changing oil more often than the maintenance is scheduled for, unless subjected to harsh conditions. Today's oils in modern engines can work effectively for much longer then the maintenance schedule calls for, but period samples must be tested by a lab to confirm that it is still good, so most of us do the normal change anyway at 5K miles.
Amdkt7 is offline   Reply With Quote
Maint Required light blinking after startup brg88tx DIY / Maintenance / Service 20 10-22-2016 09:56 PM
How many more miles can you drive when the maintenance required light starts flashing dante2086 DIY / Maintenance / Service 3 12-14-2010 08:24 PM
Will local bay area members please stand up! YarisSedan California 264 07-29-2009 12:53 AM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 09:25 PM
