![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
TRD Spings + Tokicos need camber plates?
I have TRD springs, 15" Scion aluminum wheels, and Tociko struts. The tires are P195/55/R15.
The inside of the front tires wore out in just 5k miles. I think it was just a poor alignment, or do I need to buy come sort of camber adjustment add-on? |
2ZR swap. DO IT! Ask how!
There's a good bit of adjustibility in the stock crash bolts, and the springs/shocks will change your geometry. Considering how quickly you went through those tires, $100 for an alignment is a pretty good investment.
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
I have the exact same setup.
Camber bolts are advisable, but the toe adjustment is more critical. I have no camber bolts on mine, just a toe adjustment, and no wear at 5K.
Cheapest DD I could find!! |
Only Happy When it Rains
Did you get an alignment after install? It sounds like you didn't.
Colin Chapman disciple |
![]() Drives: 2008 Yaris Sedan Join Date: Apr 2013
I pretty much just installed the same setup on my sedan. H&R Springs and Tokico Shocks/Struts (whatever you prefer to call them) on 16" rims. I got an allignment after the install and the camber was almost perfect but the toe was out a bit so got that all adjusted. Also its a good idea to get an allignemnt after the springs settle cus it could go out slightly for the extra 100 bucks its well worth it over 500 for tires. Im pretty sure the drop is almost the same for TRD and H&R springs, so its most llikely a toe issue over camber. But if its a camber issue there is some adjustment range on factory toyota crash bolt setup. Hope This helps.
Droppin Gears
| FEELER: Any interest in camber plates or hub spacers? | bzinn 1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 03-17-2010 01:44 AM |
| With TRD Springs do I need to adjust camber? | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 06-18-2009 10:51 PM |
| My latest mod... custom plates TRD VVTI | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 8 | 04-17-2009 12:03 AM |
| TRD Options | S1L3N7 D3A7H | New YARIS Purchase Forum | 26 | 01-20-2009 02:52 PM |
| Camber Plates (Gauging Interest) | misformartin | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 01-08-2009 12:21 AM |
