Old 10-12-2006, 01:16 AM   #1
as400g33k
as400g33k's Avatar
Drives: 05 YRS Silver Lining Metallic
Just wanted to share this: turbo 1NZFE
Found this, a turbo 1NZFE. The car is a Thai Vios, a Southeast Asia market-only car. It has basically the same internals as the old Echo. Here's an excerpt:
Now we come to the juicy bits. The 1.5 16 valve DOHC VVT-i 1NZ-FE engine has been turbocharged with light boost pressure as the compression ratio of the engine is still quite high for a turbo-ed engine at 10.5:1. Normal for a bolt-on setup. The ECU has been upgraded to detect boost and adjust air-fuel appropriately.
This results in 143 horsepower at 6400rpm and 196Nm of torque at 4400rpm. The gearbox is a 5-speed close ratio gearbox for maximum acceleration. This takes the car from 0-100km/h in 8.1 seconds. The car does the 400meter sprint at 15.9 seconds.
I suppose if you can lower the compression to something like 9:1 you could boost it up higher and get even better performance out of it.
More here.
as400g33k is offline   Reply With Quote
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
