Old 05-08-2013, 06:57 AM   #1
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
funk 3
Well this is a learning process. Squirting anything down the outside intake vents is useless if the cabin air filter is present. The mold killing liquid must come in direct contact with the mold. SO I removed the cabin air filter and turned on the blower fan and directly sprayed the CONCROBIUM into the blower area. Turned on the ac and ran for 5 minutes to draw liquid into ac interior. Drain hose showed a little dripping. Shut things off,will check for funk tomorrow.Removing cabin air filter was the thing to do for this process, also the filter although only 1 month old had small dirt and leaf dusty's, plus about 20 small flies in it. Cleaned filter and reinstalled.
peewee1 is offline   Reply With Quote
FUNK peewee1 DIY / Maintenance / Service 9 05-06-2013 11:14 AM
Questionable funk from the air vents SilverBack General Yaris / Vitz Discussion 25 02-03-2009 12:07 PM
