Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
Bought used yaris, smelled nice, now bad. Any help?
I bought my used yaris about a month ago and it smelled really nice on the inside. now that its a month old the nice smell has warn away and, as an ex-smoker, I can tell this was a heavy smokers car before me.
Aside from feeling like I was hoodwinked with "new car smell" from the dealership, is there anything I can do to permanently "fix" the smoker's smell? I'm willing to gut the car and wash everything if that would make a difference (or is even possible or advisable). Any suggestions? Its starting to get warmer here and just having open windows is getting to be out of the question. I'm sure when I have the AC on and windows closed %100 its going to get even worse.
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
Modded Moderator
One way is to replace the fabric on the seats, carpet, and headliner. That can get spendy. The only reason I know this is because a few years back after my yaris lost the new car smell, I got it back when my entire interior got destroyed by someone throwing a lit firework inside. Shampooing the seats and carpet would help. Getting the seats out is a pretty simple process, you'll just need the right socket at autozone or your local autoparts store.
![]() ![]() Drives: 2010 3dr yaris Join Date: Jan 2013
I would try renting a RugDoctor or something like that for a day. Only cost about 25 dollars where I live. You have to rent the car attachment as well. Also, buy the cleaner, I bought the enzyme cleaner as well for my outside room. That was because the person before me had pets and smoked. It solved the smoke smell but on humid, hot days sometimes the room still smells like dog. Good luck and if you get the RugDoctor it will take at least and hour or so to do a good job on the car. Keep the windows down if possible to allow to air dry a day.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
replace the fabrics and scrub the hard surfaces, that is why no one likes getting a car that was smoked in you can't get rid of the smell easy or cheaply.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
Replacing the fabrics gets mighty expensive. I would start with cleaning all plastics, giving the AC system a good cleaning with Ozium, and having the fabrics professionally cleaned by a good detailing shop. Also, put some baking soda in a cup and just leave it in the rear cup holder. Replace it once a week.
^^^ What does "Marine Squash" smell like?
I forgot you could replace the in air cabin filter with a carbon based one as well. Think there is a thread about Frebreeze one. Also read about someone putting coffee beans in the car. Which will only cover the smell but you may not smell the smoke.
cabin filter
I have read that some folks put a sheet of cloth dryer fabric softner in the cabin filter, good for a month or two.
I think I might try the RugDoctor thing first (or a couple times) and look for the car attachment. Does it hurt anything to use that on the headliner?
I'll try taking the seats out as well so I can really get every nook and cranny. I'll see if I can get the entire carpet out as well. Is it expensive to replace that? Its warn through where the driver's left foot rests anyway.
Get a Moso Bag lasts several years and you can keep recharging it. You put it under your car seat and it soaks up all the smells in the car. I keep one in my car at all times gets rid of the food smell if you leave a bag of mcdonalds in your car accidentally overnight. Its better and cheaper in the long run than any air freshener and really neutralizes all odors.
#12 | |
good
We used to use something similar. I'll keep looking but if you're desperate.
http://www.autogeekmobile.net/clairgefoair.html
Returning to Toyota
Drives: 2013 L 3dr MT Join Date: Mar 2013
Taking the carpet out seems excessive. Clean everything possible, wipe it down, and use the carpet upholstery cleaner on the carpet and fabric. Go light on the head liner! I think a good cleaning and a little bit of time will take care of the problem.
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
When I bought my truck it had been smoked in pretty regularly. I pulled the dash apart and washed all the AC stuff/plastics, then vacuumed all the carpets and basically soaked the entire interior in auto febreeze a couple times a day for about a week while leaving the windows open (in the garage) and eventually the smoke smell went away.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
Proud Toyota Owner
Drives: 2008 Yaris HB Join Date: Mar 2013
Rent an o-zone machine, It will take ll smells out permanently.
I'd return it to the dealer and let them take care of it. After all, they covered it up. if that does not work, you could always start smoking again.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
| WHY do I want one so bad? | YarisOwnersDad | New YARIS Purchase Forum | 308 | 09-29-2009 07:38 PM |
