Old 05-27-2013, 02:07 AM   #1
Lokie452
Drives: 2009 Toyota Yaris
Yaris and a motorcycle carrier.
Hey guys. I've had my 2009 Yaris for almost a year now. I ride motorcycles a lot and am having to do a lot of driving for school and work. I've considered getting a motorcycle carrier to tow around my little Honda rebel 250cc. It's about 340lbs. So it shouldn't be a problem for the yaris to pull me and the bike but does anyone know if the car or the hitches sold for the yaris could handle the downward weight?
Lokie452 is offline   Reply With Quote
Old 05-27-2013, 04:24 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Why not just drive the car or the bike on your errands? why the need to go every where with both of them?
If driven easy i doubt a bike and trailer will upset the handling too much.
I'll presume you are thinking of something like this =
http://upload.wikimedia.org/wikipedi...le_Carrier.jpg
And not like this=
http://cdn2.bigcommerce.com/server57...63.300.225.jpg
Have Yaris will travel..
Old 05-27-2013, 09:35 AM   #3
Lokie452
I was thinking of the first one. I've never seen the 2nd, would that actually work? It's not really errands. My school is a four hour drive away, I live in a dorm, and I'm in the co-op program where 3 semesters of interning are mixed in between normal school semesters, that is 6 hours from home and between 4-5 hours from my school.
Old 05-27-2013, 11:04 AM   #4
Lokie452
Just a quick update. I just brought my yaris in for an oil change and found out from the dealer that the yaris had a tow capacity of 700lbs, but that is only rated for Canada. Anywhere else is not rated for towing and is recommended not to tow at all. I was also told that tongue weight is usually 10% towing capacity, so I'm feeling like a carrier, while inexpensive, would lift the front tires too much.
Old 05-28-2013, 05:29 AM   #5
jambo101
jambo101's Avatar
So basically you a re just thinking about getting the bike out to your dorm so you have the option of car or bike at any given day.
You maybe able to just rent a bike trailer from a U-Haul type place or a bike shop to transport the bike.
This type will probably pushing your weight limit but if driven easy i dont see a problem with a 4 hour trip.
Old 05-28-2013, 05:35 AM   #6
jambo101
jambo101's Avatar
Or if you plan on frequent towing it might be worth your while to purchase something like this
Old 05-27-2013, 11:32 AM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The problem with trying to use a basket style is that the only hitches available for the Yaris are Class I. The hitch itself is rated for 200 lbs tongue weight (downward force on the hitch) but I'm sure the Yaris is rated for much less. You'd be safer with a trailer that was properly balanced (10-15% of load as tongue weight).
Old 05-27-2013, 11:36 AM   #8
CrankyOldMan
The Canada vs. US tow rating is purely a liability issue. There are several LONG threads here already that go into detail about why/how it's not a mechanical thing, so I'll just summarize it here: The US is lawsuit happy and prefers to sell trucks/SUVs for towing, so OEMs don't rate their smaller vehicles for towing in order to protect themselves/boost sales.
Old 05-27-2013, 01:31 PM   #9
Lokie452
Thanks for the info. I'm going to look into some small foldable motorcycle trailers or a tow dollie.
Old 05-28-2013, 06:24 AM   #10
nookandcrannycar
^^^^^ This. If all U.S. states had 'loser pays', then this might change. Our wonderful state now has loser pays.....even with the Texas Trial Lawyers Association spending 14 million USD to try to defeat such progress.
Old 05-28-2013, 10:04 AM   #11
Lokie452
I'm actually thinking of going with something more like this.
http://static.ddmcdn.com/gif/motorcy...trailers-4.jpg
I've been reading forums all over about them. Everyone seems scared to use them but everyone who actually has used them has never had any issues. Hopefully the picture shows, I haven't used forums that much.
Old 05-27-2013, 02:36 PM   #12
Trailer is definitely the way to go as tongue weight is indeed rated at 70 lbs.
Old 05-28-2013, 09:03 PM   #13
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
Don't know. That's a little scary. I'd prefer a trailer.
screenprintr is offline   Reply With Quote
Old 05-28-2013, 10:30 PM   #14
jeeper5usa
jeeper5usa's Avatar
Drives: 2011 Toyota Yaris
What about this?
Try this, it is what I found when I was looking into a light-weight trailer for my bike. Never tried it, but this is what I found. The trailer weight and tongue weight all seem to fall into the candian tow specs for the Yaris.
http://trailerinabag.com/index.html
http://www.discount-trailers.com/trailer-in-a-bag.htm
Good Luck! Post pics!
jeeper5usa is offline   Reply With Quote
Old 05-28-2013, 11:41 PM   #15
Lair
Drives: 2016 5 dr Yaris LE
I picked up a Class 1 hitch for my 3 door, and have a vintage Holsclaw three-rail trailer that i use to haul my Yamaha WR250F. The hitch is attached to the rear body panel with four 13mm bolts. That's right - FOUR bolts.
I keep waiting for the rear end of the car to detach itself.
Lair is offline   Reply With Quote
Old 05-29-2013, 09:13 AM   #16
jambo101
jambo101's Avatar
Maybe a bit of frugal creativity is in order
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-07-2012 12:37 AM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 04:13 AM
