Old 07-22-2009, 04:28 PM   #1
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
Alarm help!
I picked up a great alarm for free. I have done keyless entry and power door and windows before, but this is a whole new realm of oh crap.
So I was wondering if I could get some help from those who have done an install like this...
For starters I have etimago's link for all the service pdfs. But there isn't anything wrong with a quick hey you can find that wire here type thing.
List of wires needed to find:
Brake input (+) - ?
Dome light output (-) - ?
Ignition input (+) - ?
Door trigger (+) and (-) - ?
Armed output (-) - ? Not sure what it is either
Parking light output (+/- built in relay) - ?
Horn output (-) - ?
Thanks for any help in advance!!!
Two Yari on home!
thewifesyaris is offline   Reply With Quote
Old 07-22-2009, 11:56 PM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
i too need to find the dome light output. my alarm keeps re-arming it self not sensing a door has been open within 25sec.
o but to help you out, i was lazy and hook my parking light output to the hazard light switch in an attempt to get it to use the turn signals, but it just blinks the parking lights, i dont get it.
Check out my Build thread:
Old 07-23-2009, 11:04 AM   #3
Dome light output (-) - This is to turn the dome on - Pink wire at the dome light. To use this you would need to ground the dome light side of the wire, and at the same time open the harness side, otherwise you will pop a fuse.
Dome light input (-) - This is to sense that the dome is on (and is the one exhacker1 is looking for) - Pink wire in pin 2 of connector K2 (6 pin connector below the one with the yellow sticky note in the image below).
Armed output (-) - Not needed (only used if the car has an OEM security module)
Check out this thread for the rest:
http://www.yarisworld.com/forums/sho...ighlight=wires
Old 07-23-2009, 07:56 PM   #4
thewifesyaris
Freakin sweet thanks a bunch.
Two Yari on home!
Old 07-23-2009, 08:42 PM   #5
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Also try http://www.12voltresource.com/ its what I use to hook up neons and such.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 07-23-2009, 10:01 PM   #6
ezhacker1
ezhacker1's Avatar
thanks CTScott, i have yet to try the parking light wires, on my 09 the pin 27 is light green and pin 28 is yellow, so its switched around.
i cant use the dome input with my alarm, i found because the dome light tuns on when i remote unlock which is obviously before i open a door, it thinks that a door is already open, and wont re-arm itself after "hey no door has been open yet."
Old 07-23-2009, 10:34 PM   #7
Correct on the 27 and 28 colors. In the 07 and 09 EWD's its shown as 28 - Yellow, RH and 27 Green, LH.
For the door open indication, you can use the door courtesy switches. They are +12 V when the door is closed and 0 V when the door is opened.
4A - 21 Front LH
4A - 24 Front RH
4A - 20 Rear RH and LH
4A - 7 Hatch or Trunk
You can tie all of them together into a single input into the alarm, or if you need to keep them isolated, you can add a diode between each of the terminals above and the alarm input (with the stripe on the diode pointing towards the alarm input).
Old 07-23-2009, 10:38 PM   #8
ezhacker1
ezhacker1's Avatar
what a hard reach to get pin 21 lol. i still need to tie it with 24.
thanks a bunch for that pic, the sticky on here left me wondering.
Old 07-23-2009, 10:45 PM   #9
On that sticky, eTimago might have accidentally swapped the colors, or maybe on the Asian cars the colors are reversed.
By the way, on the door inputs, I remotely helped Taiyaki install his alarm and he used those and tied the inputs together for his.
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 03:02 AM
Improving the 'range' of your existing alarm system ad23 General Yaris / Vitz Discussion 8 04-14-2009 11:12 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 02:49 PM
alarm system concern Shroomster General Yaris / Vitz Discussion 2 09-14-2007 03:22 AM
Rant! Damn car alarm installers, trying to rip me off!!!! W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 18 11-21-2006 10:18 PM
